How To: Installing GraphicsThis is a discussion on How To: Installing Graphics within the General Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; Originally posted by strykmaster
Nice decorations Woody Now I'm really jealous and instead of wasting money on a Christmas tree, ... |
| | LinkBack (1) | Thread Tools |
#61
#62
| LOL, that is a good idea. |
#63
| Great instuctions Woody... They look great. I'll thow in a couple of x-tra tips since I do this for a living. (quite often on my bike also) 1. Stay away from Glass Cleaner if you can for application. The manufacturers recommend nothing with amonia for the adhesive. I buy application fluid, but water with a drop of Dish soap works great. Alot of sign shops still mix their own. 2. I always Clean with alchohol, like you said... it works the best. you can use glass cleaner, but make sure you get all of the residue off..... You usually have alchohol laying around anyway. 3. Use a squeegee (plastic, like a bondo spreader)... to fimly press the decals down, and to remove air bubbles and wrinkles. Do it again after it's dry (5 min. in warm weather) This is important because the adhesive is pressure sensitive. The harder you press, the better it sticks. I have sleeves for the squeegees so I don't scratch the vinyl, but you can use a rag. i usually use very thin vinyl, (2mil)- that i use for lettering signs and trucks, though... The stuff you buy for the bikes is very thick (10 mil) - and doesnt' scratch easily. just my .02 |
#64
| Cool, thanks for the tip. |
#65
| Thanks so much Woody for posting that...I am heading out right now to put mine on..wish me luck...I will get ya'll some pics hopefully tomorrow |
#66
| No problem, I'm glad it helped. |
#67
| well I got another way to do this. I guess you could say its the redneck way. But b4 I start ,Woody you did a awesome job!!!!. Here is the bubba Gump way. Go fill your bath tub up with the hottest water as you can stand. Throw your new stickers and plastic parts into the water. Do not get in with them(big mistake if your hairy). After about 5 minutes peel your sticker backing off and float your graphics into place. You can remove the bubbles out pretty easy also with your fingers. Just my way of thinking out of the box.......just not the tub,lol |
#68
| Excellent, I will use this method when I apply my ATM stickers that arrived yesterday! Thanks |
#69
| I've heard that works pretty good too, I was just too sceered to try it. Thanks Macho. |
#70
| has anyone tried just peeling off the dry graphic and putting them on the dry plastic with no heat or anything? how did that turn out? |
#71
| Sorry about this stupid question, but what exactly is "rubbing alcohol"? Is it like methylated spirits or something? My graphics arrived here and I am using a formula of water, dishwashing liquid, and rubbing alcohol. Thanks for your help! |
| LinkBack to this Thread: http://www.allthingsmoto.com/forums/f-15/how-installing-graphics-6072/ | ||||
| Posted By | For | Type | Date | |
| How-To Install Graphics - Details - | This thread | Refback | 09-09-2008 12:00 AM | |
| How To: Installing Grips | Woody_393 | General Motorcycle Knowledge Base | 83 | 11-03-2007 04:58 PM |
| Tips on installing ... | yzDirtBag | General Discussion | 11 | 05-03-2007 08:23 PM |
| Installing a Flywheel | Dirtbikindad393 | 4-Stroke Motorcycles - Yamaha | 7 | 03-01-2004 06:26 PM |
| Installing v force on cr 125... | gear graphic | 2-Stroke Motorcycles - Honda | 6 | 02-01-2004 12:25 PM |
| installing graphics | geneyz | General Discussion | 7 | 11-14-2003 12:59 PM |
