cleaning rust off of a pipeThis is a discussion on cleaning rust off of a pipe within the General Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; "3 stroke" posed a question about cleaning up a rusty pipe so i thought i'd post a few before/after pics. ... |
| "3 stroke" posed a question about cleaning up a rusty pipe so i thought i'd post a few before/after pics. this was the result of using naval jelly and a scotch brite pad. if i had bothered to use a fine steel wool pad and really work some of the spots along the seams it would have been even better but i didn't have much time. i applied the naval jelly, worked it in with the pad, and let it set up for about 15 minutes. then i rinsed it off and took the 'after' pics. before: and after: cheers, -Z |
| Looks good. I used to clean mine up every other ride but I got tired of it so it just stays rusty. I also used Scotch Brite pads, they worked good. |
| the trick to keeping it looking good after you give it the really good cleaning is to hit it with some wd-40 after washing the bike. this will help prevent it from rusting up again and will also help (a little) with as much dirt/mud sticking to it when you ride next so that it's easier to hose down afterward. -Z |
| Wow, made a great difference. If you really want to add a finishing touch, give it a final polish with some Mother's polish. |
| Naval Jelly....a dirtbikers best friend. |
| Jeess that cleaned up pretty nice. |
| I've had my best luck with fine steel wool that can be purchased at any hardware store. I also wear thick rubber gloves as the chemical in the Naval Jelly can be tough on the skin. |
| I think this needs to see the KB if everyone is agreeable? Nice Work Z- |
| For sure. Definetly KB material! I always had the perception that aftermarket plated pipes tended not to rust. However, this is a great read as I would like to purchase a FMF Fatty in the future. Thanks for that very good and informative report. |
| Yep Navel jelly works very well, also Lime-a-way will work on Works style pipes like a charm Moved to the KB. |
Thanks again psyklone393! |
| Just thinking outloud here.........What would naval jelly do to tarnished spokes? Does it harm aluminum? Last edited by OLDMXRACER 393; 11-17-2004 at 04:02 PM. |
| that stuff will eat aluminum, it's not recommended. -Z |
| All I can say is I am inspired! Where do ya buy Naval Jelly? |
#18
| i got mine at 'home depot', but i think you can get it at any hardware store. while you're there be sure to pick up a good set of gloves. as has already been mentioned, you don't want that stuff touching your skin. -Z |
#19
| I got my Fatty second hand. It has no dents or scratches. It's nice and clean, but I am just wondering how I can get the maximum shine out of it? I use scotch brite pad and WD-40. This is what it looks like now. ![]() ![]() The sun makes it look better in the pics. I am mainly after the "see yourself in it" like when it would have been when new. Although it looks OK, I would like any suggestions to further improve the shine and new look. Thanks. |
#20
| I would just use a little mothers polish and a polisher or some type of nickel polish the pipes are coated in nickel so you can just look around and try new things |
| Removing rust on FMF Fatty pipe | kjjz28 | 2-Stroke Motorcycles - General Discussion | 8 | 12-19-2008 05:12 PM |
| cleaning the inside of a pipe | 2000 cr250rider | 2-Stroke Motorcycles - Honda | 17 | 06-07-2007 11:43 PM |
| Pipe Rust. | pintlermotocros | 2-Stroke Motorcycles - General Discussion | 5 | 03-28-2005 07:08 AM |
| Rust on pipe...what to do?? | char393 | 2-Stroke Motorcycles - General Discussion | 25 | 01-29-2005 09:19 AM |
| pipe cleaning? | psyklone393 | General Discussion | 1 | 10-02-2003 10:42 AM |
