which is the best chain for power to back wheel?
This is a discussion on which is the best chain for power to back wheel? within the General Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; yep, go x-ring they are awsome!...
View Poll Results: what is the best chain for power to the back wheel?
standard chain 49 37.12%
o ring chain 29 21.97%
x ring chain 54 40.91%
Voters: 132. You may not vote on this poll
LinkBack (1) Thread Tools
  #61
Old 07-22-2004, 10:59 AM
Doom Crew's Avatar
Wreckin Ball
Last Online: 03-04-2008 10:39 AM
Default Re: which is the best chain for power to back wheel?
Old 10-06-2004, 08:15 AM
huffdaddy70's Avatar
Last Online: 07-10-2008 05:49 PM
I've heard from several different reputable sources that O-ring chains are major power robbing. If you only ride tracks, definately stick with a good standard chain.
Old 10-06-2004, 08:16 AM
***RETIRED FOR GOOD!!!!***
Last Online: 05-09-2010 11:23 PM
X-rings are a better way to go. lot better investment to help keep all the grit out and the oil/grease in. i need to get one also
Old 10-06-2004, 08:48 AM
MotoMan's Avatar
Floppy
Last Online: Yesterday 08:33 PM
They do rob a bit of HP, they take more power to turn due to the stiffness of the o-rings. HOWEVER, if you are fast enough to worry about that itty bitty bit of power loss, you probably are not paying for your chainwheels anyway and getting a new one every few weeks isn't a big deal. You would probably notice a bigger difference if you spent about a half hour in the restroom before riding if you get my drift.
I have ran o-ring chains for years, and I can honestly say that I can't notice a differance.
Just my .05.
Old 10-09-2004, 12:44 PM
bigguns30's Avatar
Last Online: 04-11-2006 07:42 PM
when i ride my kx 250 for a few minutes with my did x ring chain, the chain warms up and runs as free as a standard chain.
  1 links from elsewhere to this Post. Click to view. #66
Old 11-30-2004, 01:08 PM
Tdub's Avatar
The "ONLY" FastForward
Last Online: Today 12:53 AM
Just re-read this entire thread. For those of you have not, it really is quite entertaining. Check it out!
Since this thread has been posted, I have come up on a chain "dyno". It is basically a 1/2 hp electric motor with sprockets and a disc brake and an ohm meter attached.
The disc is for putting a load on the chain till it gets up to operating temp.
What I found would surprise you.
On first start up, the non oring chain puts very little draw on the motor, while the oringer pulls a few ohms meaning it is "dragging" more than the non oringer. BUT!!!
Once the 2 chains came up to temperature, the non oring chain drew more and more resistance from the motor.
Ready for the surprise???
The warmer the oringer got, the LESS resistance it made!
SO, my conclussion was that once up to operating temp, the o-ringer had LESS drag than the non oring chain did.
NOW, just think if we were to add a little bacon grease to the equation......Tdub
Old 11-30-2004, 02:01 PM
Keetoman393's Avatar
Out of control!
Last Online: 03-20-2010 09:56 AM
Cool, this just reinforces my belief! Yes it is harder to push the bike around when you first unload it but after a race or hard ride, it's free moving. Thanks for the test Tryce
Old 11-30-2004, 02:04 PM
Tdub's Avatar
No problem...now off to subway for a BLT!!!
Old 11-30-2004, 02:31 PM
Satch0922's Avatar
Regina O-Ring on my bike and I have adjusted it once......since JUNE!!!!!!!!
WHo cares about drag! LOL However Tryce is exactly right....once "warmed up" the oring chain actually has less risistance because it remains lubricated internally where as the non oring SLINGS all the lube off and starts to run dry.
Hey..WHAT KIND OF MOTOR OIL DO YOU USE ????? LOL JUST KIDDING JUST KIDDING!!!!!!!!!!!
Old 11-30-2004, 08:48 PM
I've been RM-Zedded
Last Online: 09-03-2010 09:25 PM
Awesome Tryce. Thanks for that info. Very enlightening.
Old 12-02-2004, 04:23 PM
Aus_Rider_22's Avatar
Mod From Down Under
Last Online: 08-18-2010 12:29 AM
I have only just read this thread.
After reading all 7 pages I am almost convinced that an O-ring chain is the go for me.
I currently have a "Izumi" chain. I am sick of having to adjust after every few rides. My $120 Talon sprocket looks new and has barely worn.
I went with a dearer sprocket and cheaper chain (dealer's advice!). But I am definetly considering O-Ring chain next. Now what sort?
What is the cheapest Gold O-Ring chain that someone has?
Thanks!
Old 12-04-2004, 08:29 AM
MotoMan's Avatar
Floppy
Wow Tryce...that is pretty interesting!
Old 12-08-2004, 07:21 PM
Zak Zak is offline
Banned
Last Online: 12-09-2004 05:09 PM
Xring!
Old 12-17-2004, 06:24 AM
gonzo's Avatar
Last Online: 10-03-2005 07:49 PM
I use the DID ERT chain. No rings and I oil it once a ride. I adjust once and never again.
Old 12-18-2004, 02:59 AM
DCox's Avatar
Last Online: 08-09-2007 09:23 AM
Heh. This thread was fun to go back and read again. Whatever happened to ol' Paul Reed? His tangents on honey pots and bacon grease used to be very entertaining.
However, I could never quite nail down exactly where his lines for reality ended and science-fiction began . . . .
T-Dub, your chain observations are very interesting. Have you by any chance run an x-ring, or would that by default of design simply fall under the o-ring category?
Old 12-18-2004, 08:51 AM
OlSchoolFool393's Avatar
Older than DIRT
Last Online: 06-13-2010 05:40 PM
Gonzo Congrates on Your return to 2 strokin , But I haven't had very good success with the DID ERT? Don't Know why But the renthall gold seemed to be a pretty good chain only stretched once But I,m going today to Buy new chain and sprockets for My RM 250 and this time it will be an O-ring and in a few months I'll have a report on wear and tomorrow after I race I'll return with a power loss or not report for You Guys and Ga'lls ?
Don W.#8
Old 12-18-2004, 10:17 AM
Tdub's Avatar
I have never done the test with an Xring...I would assume that it would be even better than the standard oringer though. Tdub
Old 12-18-2004, 02:05 PM
quadfather03's Avatar
Last Online: 08-10-2010 03:32 AM
ert is the best i have never adjusted the one on my kx125 and the racer i bought it off of said i never would have to and they are only around 56.00. They are cut to length so you will need some tools.
Old 01-29-2005, 09:47 AM
Dirtbikindad393's Avatar
Your ATM Amsoil Dealer
Last Online: 07-29-2010 02:41 PM
I use an oring chain haven't had any problems. It actually wears really nice too considering how much I am riding and racing.
Old 03-18-2005, 07:30 PM
triplestitch461's Avatar
Last Online: 05-29-2007 11:13 AM
I've got a really loose o-ring chain, to make up for suspension, seems to work good with torque.
*_RM80 all the way_*
Tags
chain, non-ring, o-ring, w-ring, x-ring
LinkBacks (?)
LinkBack to this Thread: http://www.allthingsmoto.com/forums/f-15/best-chain-power-back-wheel-5701/
Posted By For Type Date
Useful Information About Motorcycle Chains Post #66 Pingback 11-05-2008 12:39 AM
Similar Threads for: which is the best chain for power to back wheel?
power now valve vs. power blade vs. powerwing nater24 4-Stroke Motorcycles - Yamaha 15 07-17-2009 04:35 AM
Two Wheel Drive, Two Wheel Steering crfjedi393 Vintage Riding 10 03-09-2007 04:35 PM
Back wheel is funny daveythewavey19 General Discussion 4 12-30-2006 05:55 PM
lacing back wheel zion 2-Stroke Motorcycles - KTM 6 08-10-2004 11:30 AM
back wheel axel nut size? yz426f01 4-Stroke Motorcycles - Yamaha 8 04-06-2004 02:12 PM
Powered by vBulletin® Version 3.8.5
Copyright ©2002-2010, JDub Consulting, Inc. All Right Reserved.
