which is the best chain for power to back wheel?
This is a discussion on which is the best chain for power to back wheel? within the General Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; I'v never tryed using a O-ring or X-ring chain, but I like how on normal chains you can take them ...
View Poll Results: what is the best chain for power to the back wheel?
standard chain 49 37.12%
o ring chain 29 21.97%
x ring chain 54 40.91%
Voters: 132. You may not vote on this poll
LinkBack (1) Thread Tools
  #41
Old 01-04-2004, 01:18 PM
beefydog's Avatar
Last Online: 03-16-2005 03:06 PM
Default Re: which is the best chain for power to back wheel?
I'v never tryed using a O-ring or X-ring chain, but I like how on normal chains you can take them off easily when washing the bike. Usually After a day at the track or long day riding at home I take off my chain and soak it in a bucket of kerosene and scrub it really good with a wire brush. Then rinse it with a little bit of gas and hang it to dry overnight. It gets all the broken down grit out from inside the chain. I still have the OEM chain on my KX, I'v had the bike for 5 months now, but it almost time, just the other day I could notice my C/S sproket is getting worn.
Old 01-10-2004, 03:18 PM
03kx125's Avatar
Last Online: 07-01-2004 10:28 PM
beefydog I ran with my stock chain on my 03kx for 7 months when I changed it to an o-ring jchain and carefuly compared the to together I could see a noticeable differance in the length. Just a thought if I were you I would check your links for strech before replacing your sprokets.
Old 01-17-2004, 06:57 PM
CoalPilot's Avatar
Last Online: 11-26-2007 05:41 PM
I remember the days of using Bacon grease! It was long ago when I first started having an interest in bikes. This old guy (30's?, hey I was 12!) who rode mx on weekends would let me help him clean his bike and get it ready for the race. He heated up an old coffee can full of Beacon grease and soaked the chain. My mom wondered how I acquired a sudden taste for BLT's!
I also like Sidewinders. But Only their chain, I use Ironman sprockets. Had 4800 hours on my last set and you would never know it!
Old 01-17-2004, 08:09 PM
FFRacing11x's Avatar
The "ONLY" FastForward
Last Online: Today 01:48 AM
4800 hrs???
Thats 1600 motos!!
Thats 200 nonstop days!!
Thats 800 days if you rode 4 hours a day!!!
A normal Motorcycle doesnt last that long!!
Somebody call Guiness World book!!
Old 01-17-2004, 09:30 PM
paul reed's Avatar
pro class pimp
hay tryce, that`s actually 1200 days at 4 hours a day....and using only the finest grade of grease from specially bred hogs....does it count if you`re ridin in your sleep? :
Old 01-17-2004, 09:33 PM
Old 01-17-2004, 11:05 PM
CoalPilot's Avatar
OOPS! Sorry guys my bad, double hit the "0" It was supposed to be 480 not 4800. I average 12hrs week and had the last set on just under a year. they didn't show any signs of wear.
Old 05-11-2004, 11:35 AM
dirtytrixx400's Avatar
part time atv rider
Last Online: 07-08-2007 07:55 PM
RK and D.I.D. have proven their reliability to me.tsubaki chains used to be known as the best before o'rings.
chains are supposed to be strong without being too brittle,they should stretch instead of breaking.
Old 05-11-2004, 01:50 PM
Satch0922's Avatar
My new Regina O-Ring Chain. This is my first O-Ring ever. Anxious to see how it does. Tired of stretching DID and Renthal standard chains!! LOL
Old 05-11-2004, 02:55 PM
1500cr250's Avatar
Last Online: 01-20-2009 08:36 PM
might be a stupid question but...
If you have an O or X ring chain do you still need to clean it and lube it after every ride?
Whats the maintenance on these?
Old 05-11-2004, 02:58 PM
Satch0922's Avatar
clean it ...yes. With a soft brush...no wire.
Lube it.....yes, but just to keep the outside from rusting. Heavy duty chain lube is really not necessary. The cleaner the lube the better (some use WD-40 for rust protection. I am staying with my O-ring safe Silkolene).
Old 05-11-2004, 07:17 PM
KX02's Avatar
Don't tase me bro!
Last Online: 04-13-2008 06:05 PM
I currently am running a Regina standard chain on my bike. It is way tougher than the stock DID junker. It has hardly stretched, the only thing I don't like is having to lube it a couple times a day during long rides. I was thinking of going with O or X ring next time. I have heard of people having clearance problems with these though. Comments anyone?
Old 05-11-2004, 07:50 PM
MotoMojo17's Avatar
Pinger-Slinger
Last Online: 09-04-2009 11:37 AM
i have a question about these sidewinders, are they standard or o-ring and which material lasts longest on chain and sprocket? platinum sounds a lil too bling for my wallet
PS you wont believe someone is this bored [Only registered and activated users can see links. ]
Old 05-11-2004, 09:23 PM
part time atv rider
Satch0922...i hope you have good service with that regina.they look very good...but is also the only chain i ever had to break on me! i'm not blaming the chain though...i had about a year of very hard riding on it.it busted a pin in the middle and spread open/came apart.....and of course in the middle of a hill climb.i got lucky that it didn't cause anymore damage(chain whiplash to case/or cause me to crash)...my engine did rev higher than i thought it could without exsploding.this was on a modified scrambler 400 4wheeler.....it was heavy and made alot of power...i figured it was only a matter of time before it showed the weakest part on it.
Old 05-20-2004, 11:58 AM
kx_guy86's Avatar
Last Online: 06-14-2004 01:17 AM
Well I have a dumb quesiton. How can you tell if a chain is worn or needs replacing? I've got the stocker on my 2000 KX and It seems to be ok? I have replaced the sprockets though. :
Old 05-20-2004, 02:47 PM
Roostman's Avatar
"Roostman, lays an egg!"
Last Online: 04-17-2009 02:59 AM
Measure the length of a section of 17 pins and it should be no longer than 259mm or 10.2" (mm is easier to be exact). This is out of my 02 CR250 manual for a DID 520MA2 Chain. Not sure but I would think that it would be the same for most chains.
I usually go by rear sprocket wear and replace the sprockets and chain together.
Old 07-21-2004, 07:20 AM
psycho393's Avatar
I got DUALS
Last Online: Today 07:04 AM
Roostman is right the chain and sprockets should be simultaniously replaced.
Old 07-21-2004, 11:14 PM
YZGreg's Avatar
You can call me ROBOMAN
Last Online: 04-07-2006 11:32 PM
I bought a Parts Unlimited japanese x-ring chain for my bike from [Only registered and activated users can see links. ] It seem's really well made and have 15 hours on it and havent yet had to adjust it so it seem's pretty good. plus it was only $50.
P.S. Why do people think an x-ring chain transfers more power than a standard chain. It lasts way longer but has more friction.
Old 07-21-2004, 11:42 PM
I've been RM-Zedded
It doesn't. Your correct in your assumption. X and O ring are less efficient.
Old 07-22-2004, 09:18 AM
MotoMan's Avatar
Floppy
Last Online: Today 07:17 PM
Yeah but if you are fast enough to worry about that.....you ain't buyin chains.
Tags
chain, non-ring, o-ring, w-ring, x-ring
LinkBacks (?)
LinkBack to this Thread: http://www.allthingsmoto.com/forums/f-15/best-chain-power-back-wheel-5701/
Posted By For Type Date
Useful Information About Motorcycle Chains Post #66 Pingback 11-05-2008 01:39 AM
Similar Threads for: which is the best chain for power to back wheel?
power now valve vs. power blade vs. powerwing nater24 4-Stroke Motorcycles - Yamaha 15 07-17-2009 05:35 AM
Two Wheel Drive, Two Wheel Steering crfjedi393 Vintage Riding 10 03-09-2007 05:35 PM
Back wheel is funny daveythewavey19 General Discussion 4 12-30-2006 06:55 PM
lacing back wheel zion 2-Stroke Motorcycles - KTM 6 08-10-2004 12:30 PM
back wheel axel nut size? yz426f01 4-Stroke Motorcycles - Yamaha 8 04-06-2004 03:12 PM
