which is the best chain for power to back wheel?
This is a discussion on which is the best chain for power to back wheel? within the General Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; An o- ring chain will rub the cases behind the counter sprocket on the kx's , cr's and crf's. For ...
View Poll Results: what is the best chain for power to the back wheel?
standard chain 49 37.12%
o ring chain 29 21.97%
x ring chain 54 40.91%
Voters: 132. You may not vote on this poll
LinkBack (1) Thread Tools
  #21
Old 12-04-2003, 11:40 AM
Keith 455's Avatar
Last Online: 11-02-2004 10:23 AM
Default Re: which is the best chain for power to back wheel?
An o- ring chain will rub the cases behind the counter sprocket on the kx's , cr's and crf's. For what it is worth I put a set of iron-man sprockets on my steed with a did 520 ert . I have a good 5 rides on them and they flat out look awesome. I am taking them up on the 1 year guarantee .Of course I will be replacing the chain when do,but I hope they know how much some of us ride.
Old 12-04-2003, 12:05 PM
I've been RM-Zedded
Last Online: 09-03-2010 09:25 PM
Yes they do. You can get a spacer though or some reverse the countershaft sprocket. I don't like that route so I went with the washer/spacer.
Old 12-04-2003, 06:31 PM
bigguns30's Avatar
Last Online: 04-11-2006 07:42 PM
Default sprocket
does it hurt anything to reverse the sprocket?
Old 12-05-2003, 01:42 AM
paul reed's Avatar
pro class pimp
Last Online: 01-20-2010 08:07 PM
c`mon guys - shaft drive is best...just look close at my secret shaftdrive honda cr500...built by NASA-your tax dollars at work...O ring chains rob your rear wheel of horsie power...and of course REAL MEN use sidewinder chain and sprockets...check out the website-it is awesome!......Vic Krause at Sidewinder sells the best chains and sprockets in the world...but then-you really really should have known....oh yeah- avoid the roost
Old 12-05-2003, 02:53 AM
yzernie's Avatar
Moto Geezer
Last Online: Yesterday 09:20 PM
Spam??
Old 12-05-2003, 03:30 PM
RedFan's Avatar
Last Online: 08-29-2005 03:23 PM
A clean chain!!!
Old 12-05-2003, 03:56 PM
Yardpro393's Avatar
393 race team
Last Online: 07-13-2005 02:00 PM
big guns
no, it does not do anything to revrse the sprocket. the sproket flip and the washer both move the sprocket away the same amount
Old 12-05-2003, 04:39 PM
paul reed's Avatar
pro class pimp
not spam...i joke around-but vic krause (the original Mr Know It All ) did improve on the sprocket and chain...he designed the grooved cutouts to throw off the mud-he came up with quick change 2 peice sprockets for gearing changes-uses laser cutting for precision tolerances-stainless steel or tool steel-matched chain and sprockets-i know it sounds like spam-but it`s true-check out sidewindersprockets website...its important to keep the rear wheel straight in the swingarm and to make sure the swingarm can go through it`s whole range of motion without having the chain become too tight-otherwise it puts major strain on the countershart bearings....30 years ago we were dipping our chains into melted bacon grease-nowdays they sell chain lube in a spraycan...i agree with keeping it clean-that`s very important-if you have an oring chain be careful when cleaning or else you`ll damage the rubber o rings...wire brushes can rip the rubber....and remember to Avoid the Roost
Old 12-05-2003, 04:41 PM
Yardpro393's Avatar
393 race team
bacon grease??????
i did the soak in engine oil, but never bacon grease.. you guys were hardcore
the sidewinder stuff is good no doubt.
Old 12-05-2003, 05:18 PM
MotoMan's Avatar
Floppy
Last Online: Yesterday 08:33 PM
I never heard of the bacon grease either, I used to use oil like YP said, but never bacon grease.
I bet it would work well though, it wouldn't fling off that's for sure.
Old 12-05-2003, 05:19 PM
Yardpro393's Avatar
393 race team
no wonder all of the vintage guys are old and fat. they had to eat a heck of alot of bacon just to keep thier chains lubed
Old 12-05-2003, 05:55 PM
MotoMan's Avatar
Floppy
ROTFLMAO----------->Yardpro.
Old 12-05-2003, 05:58 PM
Tdub's Avatar
The "ONLY" FastForward
Last Online: Today 12:53 AM
CAREFULL!!!
Old 12-05-2003, 05:59 PM
Yardpro393's Avatar
393 race team
just picking ffr. you old fat guys rock
Old 12-30-2003, 11:06 AM
valverde's Avatar
Upright and Breathing!
Last Online: 04-28-2010 10:29 AM
This thread is making me hungry!
Did you smell bacon when the chain heated up or get hungry halfway thru a moto?
Old 12-30-2003, 11:10 AM
Dirtbikindad393's Avatar
Your ATM Amsoil Dealer
Last Online: 07-29-2010 02:41 PM
lol you guys
I have a serious question on this what is the best chain for the desert X or O ring.
Old 12-30-2003, 11:14 AM
I've been RM-Zedded
Either one will be fine. X is supposed to last a little longer but then again, they usually cost a tad more too.
For the sand, the O and X are the way to go.
Old 01-02-2004, 12:07 AM
Last Online: Yesterday 06:31 PM
the non oring racing chains are noticeably lighter when you pick them up,,maybe 4 ozs. I guess that is worth it to factory sorts.
Old 01-02-2004, 01:22 AM
paul reed's Avatar
pro class pimp
the best chains and sprockets are sidewinder....available only at sidewindersprockets.com ....anyone offering a guarantee these days? matched sets-so the chain matches the sprocket...tool steel or stainless-laser cut- even platinum-simply the best
Old 01-04-2004, 11:39 AM
04whyzee's Avatar
I need a truck
Last Online: 02-05-2009 11:42 AM
Agreed. I would not run anythign other than Sidewinder Chains and Sprockets on my bike. I cannot afford to replace the Chain/Sprocket every couple of months. I've known guys who have used their Sidewinder sets for 2 years without even havign to ADJUST the chain. This is on 426's and 500's. My uncle used to buy the cheap aluminum sprockets and cheap steel chains until I talked him into a set of Sidewinders. His 500 would eat a Sprocket and Chain set in a weekend usually but he has been running the same set of sidewinders for almost 2 years!
Tags
chain, non-ring, o-ring, w-ring, x-ring
LinkBacks (?)
LinkBack to this Thread: http://www.allthingsmoto.com/forums/f-15/best-chain-power-back-wheel-5701/
Posted By For Type Date
Useful Information About Motorcycle Chains Post #66 Pingback 11-05-2008 12:39 AM
Similar Threads for: which is the best chain for power to back wheel?
power now valve vs. power blade vs. powerwing nater24 4-Stroke Motorcycles - Yamaha 15 07-17-2009 04:35 AM
Two Wheel Drive, Two Wheel Steering crfjedi393 Vintage Riding 10 03-09-2007 04:35 PM
Back wheel is funny daveythewavey19 General Discussion 4 12-30-2006 05:55 PM
lacing back wheel zion 2-Stroke Motorcycles - KTM 6 08-10-2004 11:30 AM
back wheel axel nut size? yz426f01 4-Stroke Motorcycles - Yamaha 8 04-06-2004 02:12 PM
Powered by vBulletin® Version 3.8.5
Copyright ©2002-2010, JDub Consulting, Inc. All Right Reserved.
