Go Back   All Things Moto! Web Forums > Motorcycle Knowledge Base > 2-Stroke Motorcycle Knowledge Base
Transmission Oil Choices, What To Pick
This is a discussion on Transmission Oil Choices, What To Pick within the 2-Stroke Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; My only comment is that I wouldn't run it in a smaller bike. The oil is apparently too thick and ...
Old 12-16-2008, 03:36 PM
I've been RM-Zedded
Last Online: Today 03:53 AM
My only comment is that I wouldn't run it in a smaller bike. The oil is apparently too thick and makes the clutch not disengage. That's what my Brother-in-law saw in his sons YZ85 anyway.
Old 12-16-2008, 03:39 PM
ClosedCasket's Avatar
Rather be riding....
Last Online: 11-18-2009 07:45 PM
Originally Posted by belly View Post
i went to the honda/yamaha dealer today, and asked them what they recommended for a yz 125 (tranny oil). they told me "Pro Honda HP trans oil SAE 80w/85W". This is my first 2 stroke bike, so my question is, is this the right stuff? thanks
The guy @the honda shop recommended HP2 OMG!!!!??? jk man
Yeah its the right stuff, 80/85wt mc gearbox lube, 5/10 30 or 40, ATF etc etc, take your pick
You can get any "branded oils etc" online for wayyyy cheaper than a honda/yamaha shop fyi.
Old 12-16-2008, 04:13 PM
Dirtbikindad393's Avatar
Your ATM Amsoil Dealer
Last Online: 10-14-2009 10:24 PM
I don't suggest running a 20w-50 in a dirt bike unless it has many many hours on it and the journal tolerences are a little more loose. A 20w-50 oil is a very good weight to run in street bikes such as Harleys.
The most popular oil Amsoil sells for the offroad/powersports community is a 10w-40. This oil is formualted for motorcycles with wet clutches specifically.
I have posted it in another place but it would be appropriate here too. Its a motorcycle oil white paper and will help you know what goes on in our engines and what needs to be protected and why.
Once you have the knowledge about oils and engine needs choose a purpose formualted oil to maintain your bike and extend the life of your investment.
I recommend an multiweight Synthetic whatever brand you choose.
Of course you know what brand I would like you all to use and I offer special pricing for ATM members.
Old 12-17-2008, 03:40 PM
Last Online: 09-14-2009 04:38 PM
I run Bel ray Gearsaver in 80w-90 in my 83 RM125. That's what the dealer recommended.
It is very thin like 30wt oil. It isn't like 80w for car and truck rear ends.
Old 12-24-2008, 05:19 PM
One other thing I would like to add to this thread. Yamalube is a highly refined mineral oil, they don't hide that fact it right on the back of their bottle. The thing I want to add is mineral oils have a tendency to harden seals and orings any kind of rubber components in your engine. Synthetics will keep those rubber components hydrated allowing them longer life.
Old 12-31-2008, 02:05 AM
Last Online: 06-06-2009 12:45 PM
Originally Posted by Rockey View Post
There’s a lot of controversy about which oil is best in a wet-clutch type two stroke motor. There are also a lot of options out there to put in that high dollar transmission. Synthetic or Dyno? What weight? And most importantly, can I use automotive oils in my bike?
Lets start w/ Synthetic Vs. Dyno oil. Theres a lot of advantage to synthetic oils. One of the most important ones is lubrication. On a 4 stroke, you are told not to use synthetic on break in. This is because the superior lubrication does NOT allow the rings to seat. For the rings to correctly seat, there must be a degree of wear. So synthetic lubricates better. That’s good. Can it lubricate enough for the clutch to slip? In some instances the answer is yes, we will discuss that later. Synthetic also resists breakdown at high temps, for example, Mobil 1 5w-30, a very light oil, will protect and resist breakdown up to 400 degrees Celsius, which if an engine ever reached it would be a glob of melted aluminum. Synthetic also won’t separate at low temps (below 40) like a heavier weighted dyno oil will.
Not sure what the above has to do with a 2 stroke motor since the crankcase is separate with its own oil.
What's dyno oil? Never heard of it.
A synthetic will cause your clutch to slip.
Regular oil with no friction modifiers. Higher performance engine oils such as API SJ, SL, SM will contain some level of friction modifier. While the friction modifier improves fuel economy, it is not compatible with wet clutches used on motorcycles. The friction modifier causes the wet clutch to slip. This is especially true if the motorcycle manufacturer recommends using only engine oils carrying API SF or SG Service Categories. Many choices like 10w40, 10w30, 20w50, and so on. Or 80w to 90w gear lube found at motorcycle shops. Your preference to weight and how much you want to change it.
ATF type F transmisson fluid works too and is also cheap.
Old 01-01-2009, 04:06 AM
I've been RM-Zedded
dyno oil simply means non-synthetic.
Old 07-07-2009, 08:44 PM
Last Online: 08-02-2009 03:27 PM
ok this may have already been explained but I really don't understand all this mechanic stuff. I have a 1997 yamaha rt 180. I went to the yamaha dealer in town and picked up the tranny oil they recomended. It is a 20w 40. The only problem, it is 14 dollars a QT. I then went to auto zone. They said I could put a four stroke oil in the tranny as long as it was a similar weight. They gave me castrol syntec SAE 10w 40. It was still 7.50 a QT but better than the yamalube. Will the castrol work?
Old 07-08-2009, 09:05 PM
I've been RM-Zedded
Yes, so long as it doesn't say Energy Conserving in the circle on the back of the bottle (which most 10w40 don't) you are fine to use it. I think the Motorcycle specific oils are the "Best" but as long as you keep the oil changed frequently you should be fine.
Old 07-08-2009, 10:38 PM
Yes you will be fine. As Woody said it best for the high reving dirtbikes we ride I would stick with a motorcycle specific oil. They are forulated for wet clutch use and high heat and rpms. A motor oil isn't spcifically formulated for that. In the RT I am going to assum that your not riding it very hard unless you riding it in the street. Then your running on the upper end of rpms and heat in which case you may think about using a motorcycle specific oil.
Old 07-29-2009, 11:24 AM
Last Online: 09-30-2009 08:24 PM
I use the Honda brand in my clutch system. Why take a chance to save a few bucks now......but later on costing more when replacing the whole clutch??
Similar Threads for: Transmission Oil Choices, What To Pick
Trailer choices...? HELP ME!! mxmama393 Trailers, Toyboxes and RV's 18 06-30-2007 12:30 AM
450 choices WOJIN What Motorcycle or ATV 3 05-12-2007 02:12 PM
I have a few choices stfaulk89 ATV/UTV - Yamaha 19 04-26-2007 12:56 PM
Sprocket choices kx_rider53 General Discussion 4 10-16-2006 11:32 PM
Choices... CLM ATV/UTV - General Discussion 21 09-21-2004 09:58 PM
