Go Back   All Things Moto! Web Forums > Motorcycle Knowledge Base > 2-Stroke Motorcycle Knowledge Base
How do you stop a plug fouling
This is a discussion on How do you stop a plug fouling within the 2-Stroke Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; Can anyone help. My RM125 keeps fouling plugs after only 30 mins riding. Are there any carby adjustments like jets ...
Old 12-10-2006, 06:37 PM
Last Online: 06-07-2007 09:14 PM
Default How do you stop a plug fouling
Can anyone help. My RM125 keeps fouling plugs after only 30 mins riding. Are there any carby adjustments like jets of needle pin clip (raise / lower) that I can play with to help plugs last longer than 30 mins. When I remove the plug it is wet with fuel, and makes it impossible to start.
Old 12-10-2006, 08:10 PM
robertc's Avatar
Retired...For Now!
Last Online: 07-19-2008 08:29 PM
Default Re: How do you stop a plug fouling
rejet
Old 12-10-2006, 11:33 PM
Last Online: Today 05:24 PM
Rejet or change the fuel/oil ratio are heard a lot. There is something you should do before you consider any of that: There is a post in the archives by faded on setting the float. Start there before you consider either of the other two suggestions. Get the carburetor back to the way it needs to be to operate as designed before you go changing brass. To get the ultimate out of your RM125 you would likely need to set your jetting to the way you ride, but trying to do that before you get things like the float setting correct is a waste of time.
You don't mention if it ever worked well, or if this is something that has progressed. Worn crank seals and worn cylinders/rings/piston(s) are another thing that will make it run rich and foul. Reeds are yet another. Cheapest, fastest and easiest thing to do first is the float. The guys you see winning races on TV have it done before each event. If you don't know when yours was done last ("I think the shop did it", isn't a good indication of when) then it probably needs it. While there you can check it for leaking.
You do have a manual don't you?
Old 12-11-2006, 12:09 AM
crdemon's Avatar
THE REAL REBEL RIDER
Last Online: 01-17-2010 06:26 PM
faded has some very good writeups if carb adjustments arent doing anything it also could be an electrical problem. weak coil cdi spark plug cap rarely but do go bad. What year? Have you cleaned your airfilter?
Old 12-16-2006, 05:10 PM
Last Online: 01-19-2007 04:29 AM
Considering all the things ossagp1 & crdemon mentioned, are you certain your
gas is good? My uncle once put a little diesel in my bike's tank when I wasn't
supposed to ride it. Like an idiot I rode it, it ran for about a mile then I had to
push the darn thing alllll the freakin' way back to the house!!! Lesson learned,
end of story!!!
Old 12-16-2006, 05:14 PM
Last Online: 10-14-2009 07:10 PM
If there are no mechanical problems and jetting is close but you are still fouling plugs then try dropping down in heat range to a hotter plug. This would be true for beginners who aren't running the bike hard enough or for trail riders.
Old 12-16-2006, 06:55 PM
HiG4s's Avatar
Last Online: 01-17-2010 05:25 PM
I have done that and it does work, but in reality if the jetting is correct the plug will last months without fouling unless there is some other issue..
Is this an older bike or a new bike. Most Japanese MX bikes are jetted rich from the factory to make sure you don't burn them up when new.. generally changing the pilot jet to one size leaner makes a big difference. Riding slow is what usually fouls the plugs and the pilot jet has more effect at lesser throttle openings. I changed the pilot jet and drop the needle one clip positionon my 99 cr125 and son's 2001 YZ85 when we first got them and they hardly ever fouled a plugs.
But if it was not fouling plugs before and is now, somethine else has changed and you may need to figure out what it was before you rejet.
check out this for jetting basics [Only registered and activated users can see links. ]
Old 12-16-2006, 08:09 PM
wildchild55719's Avatar
Last Online: 04-27-2008 06:42 AM
Moto Re: How do you stop a plug fouling
that about says it all what oil ratio are you runnig ???? what kind of oil are you running ??? what plug are you running ??? when was the last time you cleaned the air filter ?? when you look down the intake boot do you see dirt ??? any water in flywheel cover ??? has any one messed with your timming ??? when was the last time you cleaned your power valve. answer these questions then i can help
P.s. is it bad when your 7 year old is correcting your spelling lol
Old 12-17-2006, 02:14 AM
Sorry guys, heres some more info on the problem. I have only just got the bike and it has fouled plugs from the start (I've only riden a few times) so it wasn't something I noticed progressivly coming on. I do have fresh gas in the tank and I'm running "Valvoline 2-stroke pre-mix" at 32:1. My plug is what Suzuki recomends in the manual B9egv. No-one has messed with the timing whilst I have owned it. I've inspected the reeds and they look okay - just stock ones but they look as though they are sitting flush and not damaged. As far as the air filter goes, I just pulled it out and cleaning now. My float level is correct aswel (14mm).
Old 12-17-2006, 08:02 AM
Henry's Avatar
^my cat's name^
Last Online: 05-24-2009 04:56 PM
dont forget to set the plug to its proper gap before putting it in too...
Old 12-17-2006, 11:55 AM
2kHondaCR500R's Avatar
Bigbore Pingers For Life!
Last Online: 03-02-2010 11:03 PM
The only time I have ever fouled a plug was for one of two reasons: 1) too rich on the carb jetting, or 2) too cold of a heat range plug.
If you know for sure your jetting is right (not rich or lean - spot on), try a step hotter plug. If it gets any detonation, then go back up to the stock heat range.
FWIW, I run a NGK #9 heat range plug in my CR 500, but with high compression and race fuel. When I run pump gas and lower compression, I use a NGK #8 heat range plug.
Check your ignition to make sure there isn't a voltage problem, or connection problem.
NGK Sparkplug Tech:
Tech Info - Spark Plugs Overview
Spark plugs are one of the most misunderstood components
of an engine. Numerous questions have surfaced over the years, leaving many people confused.
This guide is designed to assist the technician, hobbyist, or race mechanics in understanding, using, and troubleshooting spark plugs. The information contained in this guide applies to
all types of internal combustion engines.
Spark plugs are the "window" into the engine , and can be used as a valuable diagnostic tool. Like a patient's thermometer, the spark plug displays symptoms and conditions of the engine. The experienced tuner can analyze these symptoms to track down the root cause of many problems, or determine air/fuel ratios.
SPARK PLUG BASICS:
The spark plug has two primary functions:
Ignite air/fuel mixture
Transfer heat from the combustion chamber
Spark plugs carry electrical energy and turn fuel into working energy. A sufficient amount of voltage must be supplied by the ignition system to spark across the spark plug's gap. This is
called "Electrical Performance."
The temperature of the spark plug's firing end must be kept low enough to prevent pre-ignition, but high enough to prevent fouling. This is called "Thermal Performance", and is
determined by the heat range selected.
It's important to remember spark plugs do not create heat, they only remove heat. The spark plug works as a heat exchanger
by pulling unwanted thermal energy away from the combustion chamber, and transferring the heat to the engine's cooling
system. The heat range is defined as a plug's ability to
dissipate heat.
The rate of heat transfer is determined by:
The insulator nose length
Gas volume around the insulator nose
The materials/construction of the center electrode and porcelain insulator
A spark plug's heat range has no relationship to the actual voltage transferred through the spark plug. Rather, the heat range is a measure of the spark plug's ability to remove heat from the combustion chamber. The heat range measurement is determined by several factors; the length of the ceramic center insulator nose and its' ability to absorb and transfer combustion heat, the material composition of the insulator and center electrode material.
Heat rating and heat flow path of NGK Spark Plugs
The insulator nose length is the distance from the firing tip of the insulator to the point where insulator meets the metal shell. Since the insulator tip is the hottest part of the spark plug, the tip temperature is a primary factor in pre-ignition and fouling. Whether the spark plugs are fitted in a lawnmower, boat, or a race car, the spark plug tip temperature must remain between 500C-850°C. If the tip temperature is lower than 500°C, the insulator area surrounding the center electrode will not be hot enough to burn off carbon and combustion chamber deposits. These accumulated deposits can result in spark plug fouling leading to misfire. If the tip temperature is higher than 850°C the spark plug will overheat which may cause the ceramic around the center electrode to blister and the electrodes to melt. This may lead to pre-ignition/detonation and expensive engine damage. In identical spark plug types, the difference from one heat range to the next is the ability to remove approximately 70°C to 100°C from the combustion chamber. A projected style spark plug firing tip temperature is increased by 10°C to 20°C.
Tip Temperature and Firing End Appearance
The firing end appearance also depends on the spark plugs tip temperature. There are three basic diagnostic criteria for spark plugs: good, fouled and overheated. The borderline between the fouling and optimum operating regions (500&def;C) is called the spark plug self-cleaning temperature. The temperature at this point is where the accumulated carbon and combustion deposits are burned off.
Keep in mind the insulator nose length is a determining factor in the heat range of a spark plug, the longer the insulator nose, the less heat is absorbed, and the further the heat must travel into the cylinder head water jackets. This means the plug has a higher internal temperature, and is said to be a hot plug. A hot spark plug maintains a higher internal operating temperature to burn off oil and carbon deposits, and has no relationship to spark quality or intensity.
Conversely, a cold spark plug has a shorter insulator nose and absorbs more combustion chamber heat. This heat travels a shorter distance, and allows the plug to operate at a lower internal temperature. A colder heat range is necessary when the engine is modified for performance, subjected to heavy loads, or is run at a high rpm for a significant period of time. Colder spark plugs remove heat quicker, reducing the chance of pre-ignition/detonation. Failure to use a cooler heat range in a modified application can lead to spark plug failure and severe engine damage.
Below is a list of external influences on a spark plug's operating temperature. The following symptoms or conditions may have an effect on the actual temperature of the spark plug. The spark plug cannot create these conditions, but it must be able to cope with the levels of heat...if not, the performance will suffer and engine damage can occur.
Air/Fuel Mixtures seriously affect engine performance and spark plug operating temperatures.
Rich air/fuel mixtures cause tip temperature to drop, causing fouling and poor driveability
Lean air/fuel mixtures cause plug tip and cylinder temperature to increase, resulting in pre-ignition, detonation, and possibly serious spark plug and engine damage
It is important to read spark plugs many times during the tuning process to achieve the optimum air/ fuel mixture
Higher Compression Ratios/Forced Induction will elevate spark plug tip and in-cylinder temperatures
Compression can be increased by performing any one of the following modifications:
a) reducing combustion chamber volume (i.e.: domed pistons, smaller chamber heads, mill ing heads, etc.)
b) adding forced induction (Nitrous, Turbocharging or Supercharging)
c) camshaft change
As compression increases, a colder heat range plug, higher fuel octane, and careful attention to ignition timing and air/fuel ratios are necessary. Failure to select a colder spark plug can lead to spark plug/engine damage
Advancing Ignition Timing
Advancing ignition timing by 10° causes tip temperature to increase by approx. 70°-100° C
Engine Speed and Load
Increases in firing-end temperature are proportional to engine speed and load. When traveling at a consistent high rate of speed, or carrying/pushing very heavy loads, a colder heat range spark plug should be installed
Ambient Air Temperature
As air temperature falls, air density/air volume becomes greater, resulting in leaner air/fuel mixtures.
This creates higher cylinder pressures/temperatures and causes an increase in the spark plug's tip temperature. So, fuel delivery should be increased.
As temperature increases, air density decreases, as does intake volume, fuel delivery should be decreased
Humidity
As humidity increases, air intake volume decreases
Result is lower combustion pressures and temperatures, causing a decrease in the spark plug's temperature and a reduction in available power.
Air/fuel mixture should be leaner, depending upon ambient temperature.
Barometric Pressure/Altitude
Also affects the spark plug's tip temperature
The higher the altitude, the lower cylinder pressure becomes. As the cylinder temperature decreases, so does the plugs tip temperature
Many mechanics attempt to "chase" tuning by changing spark plug heat ranges
The real answer is to adjust air/fuel mixtures by rejetting in an effort to put more air back into the engine
Types of Abnormal Combustion
Pre-ignition
Defined as: ignition of the air/fuel mixture before the pre-set ignition timing mark
Caused by hot spots in the combustion chamber...can be caused
(or amplified) by over advanced timing, too hot a spark plug, low octane fuel, lean air/fuel mixture, too high compression, or insufficient engine cooling
A change to a higher octane fuel, a colder plug, richer fuel mixture,
or lower compression may be in order
You may also need to retard ignition timing, and check vehicle's cooling system
Pre-ignition usually leads to detonation; pre-ignition an detonation are two separate events
Detonation
The spark plug's worst enemy! (Besides fouling)
Can break insulators or break off ground electrodes
Pre-ignition most often leads to detonation
Plug tip temperatures can spike to over 3000°F during the combustion process (in a racing engine)
Most frequently caused by hot spots in the combustion chamber.
Hot spots will allow the air/fuel mixture to pre-ignite. As the piston is being forced upward by mechanical action of the connecting rod, the pre-ignited explosion will try to force the piston downward. If the piston can't go up (because of the force of the premature explosion) and it can't go down (because of the upward mo-tion of the connecting rod), the piston will rattle from side to side. The resulting shock wave causes an audible pinging sound. This is detonation.
Most of the damage than an engine sustains when "detonating" is from excessive heat
The spark plug is damaged by both the elevated temperatures and the accompanying shock wave, or concussion
Misfires
A spark plug is said to have misfired when enough voltage has not been delivered to light off all fuel present in the combustion chamber at the proper moment of the power stroke (a few degrees before top dead center)
A spark plug can deliver a weak spark (or no spark at all) for a variety of reasons...defective coil, too much compression with incorrect
plug gap, dry fouled or wet fouled spark plugs, insufficient ignition timing, etc.
Slight misfires can cause a loss of performance for obvious reasons (if fuel is not lit, no energy is be-ing created)
Severe misfires will cause poor fuel economy, poor driveability, and can lead to engine damage
Fouling
Will occur when spark plug tip temperature is insufficient to burn off carbon, fuel, oil or other deposits
Will cause spark to leach to metal shell...no spark across plug gap will cause a misfire
Wet-fouled spark plugs must be changed...spark plugs will not fire
Dry-fouled spark plugs can sometimes be cleaned by bringing engine up to operating temperature
Before changing fouled spark plugs, be sure to eliminate root
cause of fouling
Old 12-26-2006, 05:32 PM
Rockey's Avatar
Last Online: 12-26-2006 05:35 PM
Check the resistance in the coil if leaner carburation doesn't do the trick. You'd have to be really rich to cause that rapid of plug fouling.
Old 01-03-2007, 05:28 PM
TUK101's Avatar
Last Online: 09-23-2009 09:03 AM
I have a feeling that after you clean the air filter the bike will run longer than 30 minutes on a fresh plug. One thing that I have found out after years of working on 2 strokes is that usually if they are going to foul a plug, it is when the bike is cold, not after 30 minutes of riding. Unless it is stop and go riding and you are running the gas too rich. Get rid of the Castrol quick stop 2 cycle oil and get some good synthetic stuff. You should be able to run 40:1 with quality oil and I would almost bet that your bike runs fine after that. If not, somebody probably jetted the bike too rich for your climate or you have leaky crank seals.
Old 01-03-2007, 05:45 PM
Last Online: 06-27-2009 10:05 AM
i use to foul lots of plugs in my cr125 from babying it so i went to a br8eg from a br9eg and just started running it hard and i dont foul them any more.
Old 01-03-2007, 07:14 PM
TUK101's Avatar
One thing that I dont know if anybody brought up is that if your bike needs a top end rebuild a 125 or 2 stroke in general has a tendency to foul plugs more often. You might want to check your compression, if it is under 120-130 you may be in need of a piston and rings.
Old 07-13-2007, 09:57 AM
Last Online: 07-13-2007 11:25 AM
try a hotter plug if you dont whant to ajust the carb. my plug is a b8es mine fouled so i got a b7es it burnes hotter just go 1 number down
Old 08-09-2007, 12:18 PM
MXPUNX's Avatar
5th gear wide open
Last Online: 02-23-2010 06:03 PM
your oil could be too rich or too lean oh and buy ngk plugs thats the way to go
Old 10-04-2007, 09:37 AM
kylehereygers's Avatar
Last Online: 06-06-2008 08:33 AM
Thumbs up Re: How do you stop a plug fouling
thank you very much my bike was doing that to me for a while ...thank you man once again
Old 08-07-2008, 10:32 AM
Last Online: 09-28-2008 09:22 AM
is the pipe on your bike stock or aftermarket because if fmf or pro curcuit and jetting was never changed your plugs will foul its happening to mine right now just trying to figure out correct jetting myself for altitude i ride at.
Old 09-06-2008, 12:38 PM
Last Online: 03-17-2010 09:27 PM
If your floats are right check the needle jet setting. Should be on the second slot from the top. Air screw set one turn out to start then adjust if needed. If you still foul plugs then go to the next hotter plug. Worked for me on a 90 CR125 with fresh motor.
Similar Threads for: How do you stop a plug fouling
plug fouling Leech 2-Stroke Motorcycles - Honda 3 08-05-2007 07:23 PM
Plug fouling Leech 2-Stroke Motorcycles - General Discussion 1 08-05-2007 07:10 PM
How do you stop a plug fouling bradm 2-Stroke Motorcycles - General Discussion 23 02-25-2007 10:30 AM
PLUG FOULING bradm 2-Stroke Motorcycles - General Discussion 1 11-12-2006 10:02 PM
plug fouling souphmars 2-Stroke Motorcycles - Yamaha 8 05-18-2004 08:36 PM
