how to bleed front brakeThis is a discussion on how to bleed front brake within the 2-Stroke Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; how to gravity bleed them. step by step please.... |
| how to gravity bleed them. step by step please. |
| this is how i do mine buddy remove top off the resevour top up with dot 4 brake fluid then loosen off the bleed nipple gently squeeze the brake lever all the way in and hold it in now tighten the bleed nipple release brake lever and loosen bleed nipple sqeeze all the way in with brake and hold it in so fluid comes out the nipple just keep repeating this prosses BUT make sure you keep the resevour toped up dont let it go down to low or you will end up sucking air back in to the line another tip if your riding the night before zip tie your front brake lever up tight this will remove any air slowly over night and a firmer front brake this can be done with the back brake also just make sure you cut the zip tie off before you try and move your bike lol hope this helps use the same bleeding prosses for the back |
| one tip is cut a hole the cap off of a water bottle and take a piece of hose that will fit on the bleeder screw and put that in the bottle cap. |
| Front Brake | TheTom | 4-Stroke Motorcycles - Suzuki | 1 | 10-16-2008 11:11 AM |
| Front brake reservoir | dhighlan | Controls & Protection | 4 | 12-12-2007 11:38 AM |
| Front brake problems | skintback | 2-Stroke Motorcycles - General Discussion | 6 | 11-15-2007 02:11 PM |
| how to bleed front brake | kxrdr65 | 2-Stroke Motorcycles - Kawasaki | 5 | 06-17-2006 06:12 PM |
| Front Brake.. | ddfh_4_life | 2-Stroke Motorcycles - Honda | 23 | 12-30-2003 04:11 AM |
