Old 10-04-2014, 05:33 AM
ohiogolfnut's Avatar
Last Online: 10-04-2014 06:00 AM
I am so confued on the mix ratio. On myRM 125 im running 32:1, but running to rich. so want to drop to a 42:1,or a 40:1. cant find right ounch mixture, some say 2.6 ounces, some say 3.2 ounces. I just bought a quart of Yamalube, can some please tell me the right ounce to produce a 40:1 mixture?
Old 10-04-2014, 08:08 AM
TRexRacing's Avatar
I wouldn't run a 125 at 40:1. Tel me what you base "running to rich" on? Fouling plugs? Hard to start? Spooge from pipe?
If it's any of those jetting will correct it. In fact if you reduce the amount of oil without correcting the jetting for it the bike will run even richer than before. Combustion doesn't "see" oil. It only "sees" the gasoline and removing oil from the charge makes it "see" more fuel compounding your problem.
So tell us your problems in another thread and we'll see if we can help you sort them out.
Old 10-16-2014, 11:44 AM
2fun's Avatar
Last Online: 03-10-2020 04:53 PM
Agreed.
Old 10-19-2014, 05:07 AM
Hamersly's Avatar
Last Online: 04-17-2018 01:27 AM
Usflag
Originally Posted by ossagp View Post
You know if I took an engine apart that had a plated cylinder that had been built since 1990, and it DID NOT have cross hatch still visible I would really be shocked. Seeing 'hatch' in a plated cylinder really ins't much of any indicator of wear IMO. Oh, nothing really new on the oil front anymore, but of course anybody who doesn't run what I do at the mix I do must be totally confused and I feel sorry for them. LOL, oil conversations are at least entertaining, aren't they?
Andy,
The rationale behind the choices is a great source of grins and giggles, if nothing else!
Mark
Old 11-23-2014, 09:31 PM
Last Online: 12-03-2014 11:26 AM
just started using belray mineral at 32:1 and its been the best I've used so far
Old 11-23-2014, 10:58 PM
YZ250devin's Avatar
Last Online: 05-07-2016 12:27 AM
Run 36:1 Motul 800 Mix oil and dont look back ! People who say to run any leaner are crazy. Motul makes an excellent product
Old 05-31-2018, 09:57 PM
Last Online: 10-18-2020 01:29 PM
How many of you measure your oil amount with a kitchen measuring cup? Did you know they are often very far off the mark? I would only use a measuring cup made for motorcyclists or weigh the oil (which is what I do). I use a small digital scale. I divide the amount of gasoline by the oil ratio and then multiply by .88 to get the desired oil weight, and then I fill the container till the scale shows that amount.
Old 06-02-2018, 07:05 AM
wFo250's Avatar
will fall over
Last Online: 05-12-2021 10:54 AM
Wow thanks for that walk down memory lane I re read the whole thing for old times sake. I just mix about a gallon of gas to a couple ounces of oil and I’ve never done a top end and my weedwacker runs great!
Old 09-12-2018, 02:05 PM
I've discovered that the correct fuel/oil ratio of any oil is dependent on the oils viscosity at the upper cylinder temperature dependent on the max RPM. I've made a spreadsheet to calculate the fuel/oil ratio for any oil that has its viscosities made public. Check out my web page on the subject; All About 2 Stroke Engine Oils and my fuel/oil ratio calculator
Viscosity is the main way to know what ratio to use. Slightly offsetting that would be the additives that affect lubrication. But since they are expensive the manufacturers don't use much of them, depending mostly on the base oil(s).
Similar Threads for: 2 Cycle Oils
Trying different oils???? walnish 2-Stroke Dirt Bike Forums 3 06-03-2005 01:18 PM
Motorcycle Oils vs. Automotive Oils 2fun General Discussion 34 10-14-2004 02:31 PM
oils MGilbert 2-Stroke Dirt Bikes - Kawasaki 1 09-03-2004 01:49 PM
2 cycle oils Crazy 2-Stroke Dirt Bike Forums 25 05-26-2004 09:54 PM
450 exc oils Metal 4-Stroke Dirt Bikes - KTM 0 05-11-2004 09:16 PM
