2 Cycle OilsThis is a discussion on 2 Cycle Oils within the 2-Stroke Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; Maxima Castor 40:1 in 97 yz125... |
#41
| Maxima Castor 40:1 in 97 yz125 |
#42
| i dont think i would want to run that ratio u would want to run a 32:1 or 4ounces or 3 ounces to 1US gallon. |
#43
| ive always ran 40:1 never had a problem |
#44
| We always ran my sisters Banshee 40:1 and it ran great for years. With that said we ran a good oil. |
#45
| We run both of Jacks KTM 200's at 40:1 using Amsoil Dominator 2 cycle oil. Last edited by Dirtbikindad393; 12-16-2008 at 03:14 PM. |
#46
| i use klotz superteciplate in my rm 250 mixed at 32:1 runs fine fer me and i sometimes use the mc1 by belray |
#47
| Ahh what the heck. I run Klotz Benol at 40:1 with octane booster mixed with 93 pump gas. My Octane should be around 96-98 with the booster. Everything runs good, don't have any plug fouling problems or excess spooge. |
#48
| Doesnt the ethanol they add to gas act as an octane booster? |
#49
| I may be wrong, but the way that I understand it, the ethinol actually helps draw oxygen into the cylinder and helps things burn cleaner. It can also cause jetting problems if your engine is not jetted for that type of fuel. As for the oil ratio I run, I have found 40:1 to work just great. I like running Klotz oils with the benol, but when funds are tight the Yamalube works pretty well too at the same ratio. For air cooled engines I will drop to 32:1 for those. |
#50
| i have a yz85 and i use motul and mix the ration 40:1. in the manual its says 32:1, thats when the oil starts spiting out of the exhaust |
#51
| Well, I found a good bargain on ebay and bough 2 gallon of benol for 32.50 each so I'm happy with it and then out of curiosity and for old time sake, looked up for some castrol R40 and holy sweet, found some and bough 4 gallon of it to (Cant beat that castor smell in an old bike). I'll run the castrol R40 at 24:1 with supreme added with some octane booster. Yes I know that she might leave some gums and smoke a bit but what the hell? Both my bike (RM250 83 and YZ490 89) dont have a power valve to gum up. I'm going out for a ride this weekend and I'll check my brand new plug when I'll get back. I'll let you guys know how it'll turn out. I never got a problem back in the eighties with the R40 and hope that it'll be the same nowadays. Josh |
#52
| I run Pennzoil semi synthetic outboard motor oil in my RM250. PE175, and my GT750 Triple, 32 to 1 in the dirtbikes and in the pump on the Waterbuffalo. I used to run Suzuki CCI but it is no better than the Pennzoil, I get it for $12 a gallon a wally world. |
#53
| I run Maxima Castor 927 at 32:1 in my 2002 CR250 when riding in the sand. 36:1 when riding in the woods. |
| Trying different oils???? | walnish | 2-Stroke Motorcycles - General Discussion | 3 | 06-03-2005 01:18 PM |
| Motorcycle Oils vs. Automotive Oils | 2fun | General Discussion | 34 | 10-14-2004 02:31 PM |
| oils | MGilbert | 2-Stroke Motorcycles - Kawasaki | 1 | 09-03-2004 01:49 PM |
| 2 cycle oils | Crazy | 2-Stroke Motorcycles - General Discussion | 25 | 05-26-2004 09:54 PM |
| 450 exc oils | Metal | 4-Stroke Motorcycles - KTM | 0 | 05-11-2004 09:16 PM |
