Go Back   All Things Moto! Web Forums > Motorcycle Knowledge Base > 2-Stroke Motorcycle Knowledge Base
2 Cycle Oils
This is a discussion on 2 Cycle Oils within the 2-Stroke Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; Originally posted by Rockey From what I have read, 2 smokes make best power at 18:1. I really don't see ...
Old 01-16-2003, 12:37 PM
2fun's Avatar
Super Sonic Moderator
Default Re: 2 Cycle Oils
From what I have read, 2 smokes make best power at 18:1. I really don't see the point in mixing 100:1 at all. You spend the same money for the oil as at 32:1, but there is less of it to protect bearings, lube piston, seal rings, etc etc. Your bearings won't last as long, there will be more wear on the engine. You will spend more money down the road.
I'll stick to my nice and polluting 26:1 ratio w/ MX2t.
I agree to not going to a ratio as lean as 100:1, but with the newer oils (synthetics), I feel that I am getting as good or better protection at 50:1 than I did at 32:1 with the older non-synthetic oils.
I'm not sure though what you mean by spending the same amount of money for the oil as at 32:1?
If you are running less oil, you are actually stretching the oil out farther, thereby spending less on oil than you would have at the 32:1, or did I misunderstand you?
One of the things I like about running the Amsoil 2000 fully synthetic (50:1), is that (I feel) I get better protection than the Golden spectro semi-synthetic mixed at 40:1
Although the Amsoil is more expensive oz for oz, I actually wind up spending LESS overall for the oil than I did when using the Golden Spectro semi synthetic.
Therefore I don't spend the same amount of money on oil. I actually spend less.
Old 01-16-2003, 03:27 PM
Rockey's Avatar
Originally posted by 2fun
A. I agree to not going to a ratio as lean as 100:1, but with the newer oils (synthetics), I feel that I am getting as good or better protection at 50:1 than I did at 32:1 with the older non-synthetic oils. One of the things I like about running the Amsoil 2000 fully synthetic (50:1), is that (I feel) I get better protection than the Golden spectro semi-synthetic mixed at 40:1
B. I'm not sure though what you mean by spending the same amount of money for the oil as at 32:1?
Let me try to explain myself a little better,
A. I also agree with you that you are getting better protection at 50:1 w/ synthetic than with GS non syn. at 40:1. I run fully synthetic Mobil MX2t, and at 32:1 or 26:1 or whatever im using depending on the ride, I feel I get much better protection than running the amsoil at 100:1. At 50:1 with the Amsoil 100:1 oil, you probably get the same as I do protectionwise.
B. What I meant by saving money was, I get MX2T by the case, it comes out to about $2.75 a bottle. For the Amsoil 100:1, it sells locally for about $7 a bottle. The Amsoil would get me through about 4 1/2 gallons of gas at 40:1 (the lowest I would ever go on a 125, on a 250 I would run 50:1). The MX2T, gets me through 3 1/2 gallons on a bottle. So moneywise, I save.
But at 50:1, that Amsoil 100:1 oil probably is a great lubricant. Im not against it, just the 100:1 ratio.
P.S-I used to use that Golden Spectro stuff too, I didn't like at at all. It gummed up PV's and has bad carbon build up on the piston. Plus at $5 a bottle going through 3 gallons a bottle, I passed on it.
Old 01-16-2003, 04:56 PM
Dell30rb's Avatar
man, I think I am going to try some of that amsoil at 80:1, sounds like a plan to me.
Rockey, have faith in the oil my friend
Old 01-16-2003, 05:24 PM
Madman393's Avatar
ATM Founder
Last Online: 09-14-2008 11:43 PM
One thing to remember about two cycle oil--it is about the best octane booster you can come up with as it reduces combustion chamber temps, detonation and the like. Therefore, when you alter your ratio, you may lose power through pre-ignition, detonation, etc.. There is a diminishing return and I would never go above 50 to 1 no matter what the oil is on MX bikes and that would be on a big bore at that.
Put it to 32:1, 40:1 or 44:1 depending on your displacement and jet for it. Then leave it alone and enjoy!
Old 01-16-2003, 07:39 PM
KTM250rm393's Avatar
Hey Coach
Last Online: 05-20-2007 11:47 PM
I agree with Tyler,
High revving engines like the 125 should stick to 32:1. Bigger bores like 250 and above can run at a higher ratio because their rpms are slower.
Old 01-16-2003, 09:55 PM
HiG4s's Avatar
Last Online: 10-29-2009 09:37 PM
Originally posted by KTM250rm
I agree with Tyler,
actually there is more to it than that.
What lubes the crank in a two stroke is the oil that falls out of the mix and ends up in the bottom of the engine. The higher the mix ratio the less available to end up on the crank. The bigger the engine the more mix runs through the engine the more oil to end up in the bottom per given mix ratio.
Old 01-17-2003, 12:10 AM
Woody_YZF's Avatar
ATM Store Mgr & ATV Mod
Last Online: Yesterday 01:44 PM
Down at my shop I sell Klotz R50 more than anything and most people run it at 40:1. A close second is the Ipone 2 stroke oil. I personally like it because it smells so good (strawberry).
Old 01-17-2003, 04:04 PM
2fun's Avatar
That makes sense!
Old 01-21-2003, 01:52 AM
hardlydangerous's Avatar
Last Online: 01-09-2009 03:16 AM
I have never been a fan of ratios higher then 50:1 either.
Really what are the benefits or running your engine on such little amount of oil?
Years ago we had a customer with a 440 liquid arctic cat that was continuously in our shop. We would rebuild it, within a month or two it was blown up, He always complained of the jetting and at tear down time the engine usually had signs or pre-ignition and or detonation.
We could never figure it out. On a fresh engine (Amsoil 40:1) it ran mint, plugs checked perfect, water temps good.
With in a month it was blown up.
We found out later he had been using an oil (not amsoil) at 100:1
My opinion is just because an engine can run with an oil ratio mixed at 100:1 does not mean that it's best for it. Sure at synthetic at 100:1 may provide the same lubrication as a cheapy-do oil at 50:1 and not void a warranty but that good synthetic mixed at 50:1 will provide twice the lubrication.
Run the heaviest oil ratio you can and not foul plug continuously... and for Gods sake re-jet for the different ratios.
Old 01-21-2003, 05:57 AM
Keetoman393's Avatar
Out of control!
Last Online: 10-01-2009 07:24 PM
I only ran 100:1 in my Trials bikes because the factory recommended it. In my other 2-smokes I ran 40:1
Old 01-21-2003, 09:51 AM
Madman393's Avatar
ATM Founder
This amplifies my point on the oil being a octane booster. Although the oil can lubricate at 100 to 1, the compression ratio of the engine and the jetting is dependent on a much lower ratio, leading to elevated temps, detonation and blown up engines.
Old 01-21-2003, 04:37 PM
Rockey's Avatar
It can lubricate, but not well. Plus you lose power.
So you lose HP, Your engine is much less reliable, You still pay the same price.
Gee, I think I will start mixing 100:1 TODAY! :
Old 01-31-2004, 11:59 PM
2fun's Avatar
Thought I would bump this with the current discussions going on about oils and mixtures.
Old 02-09-2004, 02:15 PM
MATTXR250R's Avatar
Retired ATMer
Last Online: 08-27-2008 08:35 PM
GREAT INFO...I will however stick with 32:1 in my CR250
Old 12-20-2006, 03:05 PM
jason33's Avatar
Last Online: 01-06-2008 08:16 PM
klotz-40:1-pump fuel-
klotz is great oil-it burns clean,and removes carbon build up-
possibly 32:1 with race fuel- race gas burns cleaner ,and better,always check the plug to make sure your not running too lean
Old 04-01-2007, 12:22 AM
05YZ250's Avatar
Last Online: 11-19-2009 08:19 PM
Klotz Supertechniplate 32:1 here running strong!
Old 05-14-2007, 12:26 PM
Rm rider 69's Avatar
Last Online: 09-08-2008 05:36 PM
i run Red-line with a 42:1 in my Rm 125, i ride very hard and have no issues with it at all
Old 06-10-2007, 04:49 AM
Squigs's Avatar
Punk Rock Rider
Last Online: 08-28-2009 02:28 PM
Klotz R50 at 40:1.
Old 06-13-2007, 05:57 PM
MXPUNX's Avatar
5th gear wide open
Last Online: 11-16-2009 06:51 PM
silcoline 32:1
motrex 32:1
Old 06-24-2007, 11:05 PM
Last Online: 08-30-2007 02:33 PM
Originally Posted by KTM250rm393 View Post
The only disadvantage is you can only find it at Auto Zone auto parts.
dont see the disadvantage, auto zones are everywhere, way closer and easier to find than bike shops. In my city anyways
Similar Threads for: 2 Cycle Oils
Trying different oils???? walnish 2-Stroke Motorcycles - General Discussion 3 06-03-2005 02:18 PM
Motorcycle Oils vs. Automotive Oils 2fun General Discussion 34 10-14-2004 03:31 PM
oils MGilbert 2-Stroke Motorcycles - Kawasaki 1 09-03-2004 02:49 PM
2 cycle oils Crazy 2-Stroke Motorcycles - General Discussion 25 05-26-2004 10:54 PM
450 exc oils Metal 4-Stroke Motorcycles - KTM 0 05-11-2004 10:16 PM
