$17 Leak Tester (2-Stroke)This is a discussion on $17 Leak Tester (2-Stroke) within the 2-Stroke Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; wheres the picture?... |
#21
| wheres the picture? |
#22
| I dont see the pictures either but i think i get the idea on how to build one. But i have one question, how do you pressurize your motor? Tire pump, air compressor???? |
#23
#24
| i dont see the pics. i am thinking the valve stem is with the gauge to pressure the line. i have a rm 125 that is sucking oil into the cylinder and i changed the seal but it still leaks. this will be a great cheap way to check it. thanks faded. |
#25
| i built one and got a valve stem from pep boys then drilled out a pvc 1/2 cap and put the stem thru it to pressure it. now the problem. it is a 1987 rm 125. when i put pressure to it the exhaust valve opens and lets the pressure out. does this mean it is pushing past the rings and i need to do the top end or is it something i am missing? thanks for any help. |
#26
| I would have to say yes, you are leaking past the rings. But first, are you checking with the piston at tdc? And also, if you are leaking oil into the cylinder and you replaced a seal, which seal did you replace? Clutch side or mag side? |
| 2002 RM 250 Problems continue/ leak down tester picture needed | Fluffyhead | 2-Stroke Motorcycles - Suzuki | 7 | 12-08-2008 11:23 PM |
| Leak down tester... | CaRdinalFan450 | General Discussion | 2 | 10-27-2005 01:22 PM |
| Leak Tester Build Question | Yamadog | 2-Stroke Motorcycles - Honda | 17 | 01-18-2005 02:25 PM |
| leak tester | Yamadog | 2-Stroke Motorcycles - Honda | 2 | 01-11-2005 02:39 PM |
| leak tester | Yamadog | 2-Stroke Motorcycles - General Discussion | 0 | 01-04-2005 01:39 AM |
