yz426 Tranny Problems! HELPThis is a discussion on yz426 Tranny Problems! HELP within the 4-Stroke Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; Just looking for someone to give me some info on my 02 yz426. When I shift into 5th gear, it ... |
| Just looking for someone to give me some info on my 02 yz426. When I shift into 5th gear, it slips a couple quick times before taking on off. Has anyone had this problem before, or maybe know what is going on, before I tear into it. Thanks |
| You have just become a member of the "blown 5th gear club". You will need to tear into it. Not an easy job but it's doable. Do you have a magnetic drain plug? If you do I promise you there is a piece of your 5th gear on it! Pull it apart and inspect all of the gears. You want to look closely at 3rd and 4th while your in there and if they look worn replace them. |
| Yep, welcome to the club of the 426 5th gear breakers. Sorry about that man... it was Yammies fault for not doing better testing and inspection. Best of luck to you. |
| I am so slow mine has never seen 5th gear! LOL |
| Found this on another site: Here is your problem. This was my 3rd gear. as you can see the the wheel has round edges and that causes it to try to push the fork away. That«s why it feels like it is slipping, that is everytime you deliver throttle and power enough for the wheel so that it can«t hold its position. Just replace the shift fork and the two wheels that are supposed to be held together when 5th gear is engaged.. [Only registered and activated users can see links. ] [Only registered and activated users can see links. ] |
| That is exactly what happened to mine! |
| Wow, good info here guys, possible KB canidate? |
| Possibly....that way I can find i when I blow mine up! LOL |
| Thanks, you all been very helpful!!!! |
| Looks like it's here now. |
| yz426 or yz450? | HarryH1985 | 4-Stroke Motorcycles - Yamaha | 26 | 10-29-2009 09:07 AM |
| Yz426 Crank ? | ca_101 | 4-Stroke Motorcycles - Yamaha | 5 | 02-04-2009 11:09 AM |
| 2002 YZ426 Carb problems | kvcconstr1 | 4-Stroke Motorcycles - Yamaha | 3 | 06-01-2008 10:49 AM |
| Need Help with YZ426 | Psycho | 4-Stroke Motorcycles - Yamaha | 30 | 10-15-2003 07:29 AM |
| YZ426 mod | Psycho | 4-Stroke Motorcycles - Yamaha | 14 | 09-23-2003 08:05 PM |
