get your free PowerNOW!
This is a discussion on get your free PowerNOW! within the 4-Stroke Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; Originally posted by yamaha.dude It is more than just the airflow speed... though ultimately that is the large part... it ...
Old 02-05-2003, 02:40 PM
Ty- Ty- is offline
Default Re: get your free PowerNOW!
It is more than just the airflow speed... though ultimately that is the large part... it is basically presenting a smaller size at part throttle openings and stopping a lot of the air hitting the slide and then having to deflect down the face of the slide and then turn rightangles into the throat of the carb... I will draw a pic of what would be the ultimate powernow type device... a constantly variable deflector that moved in sync with the slide...
David
Would not a series of "wings" stacked and spaced (I suppose the spacing being the big unknown) accomplish this??
Old 02-05-2003, 02:53 PM
Ty- Ty- is offline
Default Hang on....
I can recall with a fair degree of uncertainty, a discussion on some tech board, referring to devices in the intake tract to smooth airflow through the venturi. At the time, (I haven't visited the board forever and can't even remember which one it was) after some lengthy hypothesizing, someone suggested a bundle of hex shaped straws (picture a honeycomb) completely filling the bell to the slide. Don't know if it made it to experimental stage, but seem like it would provide the variable powernow.
Old 02-05-2003, 02:54 PM
yamaha.dude's Avatar
Last Online: 08-15-2003 06:46 PM
I am sure if you sat down you could come up with numerous concepts and variations on the theme... the single plate works well and the majority of riders will get some benefit out of it... to get too complicated, you would have to amke sure everything in the engine was running at 100% efficiency... ports were shaped ans smooth, biggest valve syou could get, optimum jetting, ideal exhaust...
Just the simple mod will amke your bike more useable down low...
Cheers,
David
Old 02-07-2003, 05:43 PM
tc66nova's Avatar
Last Online: 05-22-2003 03:13 PM
I enjoy the way a four stroke will lug out of a slow turn and blast down the track to the next obstacle, but do the james now and you won't believe it. The bike pulls harder down low it starts easier it idles better... I am totaly happy with the mod and especialy for no $ and about a half hour of labor. Do the mod and if for some reason you don't like it It removes in minutes. Thanks james, chris and others that helped post the pics and info.
Terry
Old 02-08-2003, 03:43 PM
Blue Beast's Avatar
Ride or be ridden
Last Online: 11-07-2006 10:06 PM
I've tested mine now and all i have to say is two words "do it"
Steve.
Old 02-08-2003, 04:57 PM
jmiakaike's Avatar
Moderatorus Dirtbikeus
Last Online: 03-04-2004 01:32 PM
Terry
Terry,
you are quite welcome! i am glad you tried it... i know that if anyone does try it, they will love it!
again, glad you tried it!
james
Old 02-08-2003, 05:28 PM
Blue Beast's Avatar
Ride or be ridden
The only other thing i have found is some loss of power at WOT and higher rpm's due to the turbulance being somewhat taken away hence losing the "better" vaperisation at WOT but what percentage of the time can anyone hold WOT on the trails?? maybee 10% unless you ride a ts185 of corse.
Steve.
Old 02-08-2003, 05:34 PM
jmiakaike's Avatar
Steve.
Blue,
probably less than that.. saw the readouts of some data acquisition from a race bike doing laps at Laguna seca.. wfo throttle was less than 5%... and, the plate shouldn't affect wide full open at all, since there should not be as much turbulence there to begin with.. but, even if there is, i will take that trade off for how it rides....
i love the thing....
lol
james
Old 02-08-2003, 05:52 PM
Blue Beast's Avatar
Ride or be ridden
The only reason i noticed a difference up top was due to a straight liner with my brother and his 426, last week we had a rolling start from 90 ks up to 140 ks and my bike was in front, this week i couldn't get in front, thats not a problem for me, just a comparison check like we always do before we change both bikes
What i gained up top with the 450 cam, i lost with the james now, like i say thats not a problem for me because the bottom end has more torque and is smoother resulting in faster rider allround.
Steve.
Old 02-08-2003, 06:06 PM
jmiakaike's Avatar
Steve.
ah.. that is good to know.. did you do any re jetting? the original site said you may have to go leaner... how is that 450 cam working for ya? going to order one for a friend to put in.. let him go first...lol
Old 02-08-2003, 06:31 PM
Blue Beast's Avatar
Ride or be ridden
My jetting feels O.K but i havn't checked the plug yet, the 450 cam gives tripple the effect of the james now, mine is still going strong i took a look at it last weekend and it looks great, i have 748 ks on it now.
Steve.
Old 02-08-2003, 06:32 PM
jmiakaike's Avatar
sounds good! will order one for him soon...
thanks!
james
Old 02-10-2003, 01:19 AM
Blue Beast's Avatar
Ride or be ridden
James, checked my plug today, it wasn't as tanned as i would like, may have to pull the jetting back a bit with the James now.
Steve.
Old 02-10-2003, 10:00 AM
jmiakaike's Avatar
Steve.
Steve,
let us know.. the original site did say you may have to go one step leaner...
james
Old 02-10-2003, 11:59 AM
Rockey's Avatar
Before I completely screw this up, the jamesnow goes in between the airbox and the carb, with the metal almost touching the carb right?
Old 02-10-2003, 01:20 PM
Blue Beast's Avatar
Ride or be ridden
Right.
Steve.
Old 02-10-2003, 01:42 PM
tc66nova's Avatar
You will need to file the end at a taper and trial fit until it stops just short of the slide. I made mine stop about .100 before the slide and it works great. Just be sure that it can not slide up and hit the slide under any circumstances because that could be ugly and really dangerous.
Old 02-17-2003, 02:48 PM
yamaha250F's Avatar
Last Online: 06-07-2004 12:36 AM
Those of you who have done this did you need to change your jetting? How did the mixture run afterwards????
Old 12-20-2003, 09:10 AM
ThumperTDC's Avatar
Last Online: Today 10:09 AM
Does anyone have new links for this mod? The links posted dont seem to be working.
Thanks,
Old 01-05-2004, 04:40 AM
Frakke's Avatar
Last Online: 10-01-2007 03:29 PM
I also am dying to do this mod but the link doesnt work. Is there anybody with another link or pictures so I know how to do it and what to use, thx!!!
Similar Threads for: get your free PowerNOW!
powernow system tHeKiNgMaN 4-Stroke Motorcycles - General Discussion 15 09-25-2006 06:19 PM
Powernow OldFossil 2-Stroke Motorcycles - General Discussion 12 01-17-2006 08:38 PM
Powernow 2001yz250f 4-Stroke Motorcycles - Yamaha 6 04-08-2004 04:09 PM
Free PowerNow!???? 83SuzukiRM250 General Discussion 0 01-06-2004 09:47 PM
Powernow Frakke General Discussion 4 01-05-2004 10:27 PM
