get your free PowerNOW!This is a discussion on get your free PowerNOW! within the 4-Stroke Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; Did you guys get the pics?? i am a computor idiot :... |
#21
| Did you guys get the pics?? i am a computor idiot |
#22
| Who did you send them to? |
#23
| Odviously, you didn't get yours, i will try again. Steve. |
#24
| Here are the pics Steve (Blue Beast) wanted posted. I have cropped both of them so they are smaller and should load quicker. |
#25
| DOH!! Looks like the Image option is turned off for this forum. I can see from the bottom options that it is indeed turned off. None the less you can still click on the links and see the pics. If someone wants to have one of the admin mods turn this option on for this forum you will be able to see the pics without having to click on them. |
#26
| Thanks Woody. Steve. |
#27
#28
#29
| Im amazed a simple mod mkes so much difference, I can't wait for my 426 so I can try it! |
#30
| James, Is the template I drew correct? I have a couple of guys over on the WR$xx side at TT saying it is wrong... I tried to explain I got the pics from one source and the template dimensions from you, another source... the pics were not of the one you have described, but offer an illustration of the principles and the basic fitting technique... I said I would check with you and get back to them... perhaps you could pop over and explain your "longer than the pictures show" one to them... Any other pics or changes, just let me know... Cheers, David |
#31
#32
the pic is spot on.. and i did make mine slightly longer than the original. the original sits flush with the bell, mine protrudes a bit more... to smooth it out a bit more and be different for patent reasons... i will check TT and let them know... thanks for your help! the offer stands, i will send you one if you like. James |
#33
| James, your PM inbox is full... I will send via the MotoEmporium e-mail thing on your profile... I don't have your direct e-mail address... Cheers, David |
#34
just got that message.. cleared out some old messages... my email is [Only registered and activated users can see links. ] feel free to email me anytime. James |
#35
| David, will this moad work on my KTM 450exc from what i here it has the same carb.? |
#36
| It should work with any bike, all you need to do it to adjust the dimensions to suit... for smaller bore carbs, you would have to make the plate narrower... to suit the bore of the intake throat, and perhaps shorten the length... though as long as it doesn't hit the slide, the airbox side can be a bit longer... A flat slide carb would be best, but once again, you could modify the end to be concave and more closely 'seal' up to the slide... if the KTM has the same intake bore, then you are in business... you can always trim the length back with tin-snips if it is too long for the KTM... It will work with the CRF, all sorts of bikes... Just need to get the dimensions right for that model... see how it is put into the bike, and you will see how big it needs to be on your bike... Cheers, David |
#37
#38
| Im going to try one for my buds XR200, but just to clarify, should the metal be almost touching the slide? |
#39
| As close as posible i beleive. |
#40
james |
| powernow system | tHeKiNgMaN | 4-Stroke Motorcycles - General Discussion | 15 | 09-25-2006 06:19 PM |
| Powernow | OldFossil | 2-Stroke Motorcycles - General Discussion | 12 | 01-17-2006 08:38 PM |
| Powernow | 2001yz250f | 4-Stroke Motorcycles - Yamaha | 6 | 04-08-2004 04:09 PM |
| Free PowerNow!???? | 83SuzukiRM250 | General Discussion | 0 | 01-06-2004 09:47 PM |
| Powernow | Frakke | General Discussion | 4 | 01-05-2004 10:27 PM |
