CRF450R Fuel in frame Mod
This is a discussion on CRF450R Fuel in frame Mod within the 4-Stroke Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; The fuel stops where the main spars are welded to the section that the footpegs bolt to - if you ...
Old 12-02-2005, 07:26 AM
Last Online: 11-11-2009 09:17 AM
Default Re: CRF450R Fuel in frame Mod
The fuel stops where the main spars are welded to the section that the footpegs bolt to - if you look at the frame the reason is quite obvoius as the foot peg section is not at all hollow.
The affect on handling would be minimal. We are talking about half a gallon of fuel when full, about half of that will be below the CG of the tank so that's roughly a quart that placed lower. A quart of fuel weighs just over a pound. Now, you could argue that with that quart placed lower you could run a quart less in the main tank, which will also slighly lower the CG of the main tank. In the end, there should be a very small, perhaps inperceptible benifit. Also note that the fuel in the frame is likely to be slightly hotter than the fuel in the main tank. This will, in theory, very slighly degrade performance.
Old 12-02-2005, 08:27 PM
Last Online: 08-27-2009 08:07 PM
it looks like the MSHSS has a rule that does not allow this mod
Old 02-11-2007, 03:28 PM
Last Online: 03-01-2007 11:17 AM
Default Re: CRF450R Fuel in frame Mod 2002 cr250
I tried fuel in frame mod on my 2002 cr250. The frame had too many leaks. I used air pressure and there was air blowing out by the down tube of the frame. If anyone has any luck with this model please tell me what you did.
Old 02-14-2007, 04:02 AM
Semper Fidelis
Usflag Re: CRF450R Fuel in frame Mod
To date I have not heard of a CR 250 or 125 aluminum framed bike with this mod. it has kind of gone quiet as a modification for some reason. I suspect the Clarke and IMS off-road tanks that are available have filled any needs.
I do think that this current and last generation of aluminum frames on the Honda 2T bikes would hold fuel since they constantly improve QC at Honda, I have no way of knowing this now since we don;t have the CR 125R any longer. However, the new small spars would not make the mod worthwhile as far as additional fuel I imagine.
Bill
Semper Fidelis
I do think that this current and last generation of aluminum frames on the Honda 2T bikes would hold fuel since they constantly improve QC at Honda, I have no way of knowing this now since we don't have the CR 125R any longer. However, the new small spars would not make the mod worthwhile as far as additional fuel I imagine.
Bill
Similar Threads for: CRF450R Fuel in frame Mod
crf450r 06 nate07 4-Stroke Motorcycles - Honda 4 12-03-2007 09:41 PM
Fuel in frame mod? AKColby 2-Stroke Motorcycles - Honda 22 04-07-2007 11:47 PM
How to Tip - 4 stroke fuel screw secretsÊ HOW TO TIP - 4 STROKE FUEL SCREW SECRETS Satch0922 4-Stroke Motorcycle Knowledge Base 4 02-14-2005 11:04 AM
03' CRF450R vs. 04' CRF450R 4strkepwr660R 4-Stroke Motorcycles - Honda 4 09-03-2004 11:06 PM
FS: 2003 frame, 2000 frame & subrame, and a 2000 swingarm nothing MC & ATV Parts & Accessories 0 01-16-2004 02:11 PM
