CRF250R Tranny Puzzle
This is a discussion on CRF250R Tranny Puzzle within the 4-Stroke Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; As many of you know, jr. left a bunch of oil out on the track our last ride at Nocona. ...
Old 07-13-2006, 09:31 PM
crfjedi393's Avatar
Obi Wan Kenobody
Last Online: Yesterday 01:16 AM
Default CRF250R Tranny Puzzle
As many of you know, jr. left a bunch of oil out on the track our last ride at Nocona. He finally slowed down enough from the "teenage" thing and we took a hard look at the bike. rbm33 is helping us out with his many years of knowledge. The bike had good compression and plenty of oil in the engine side. It even started easily. Going through the gears brought a pretty nasty noise in 4th. We pulled the tank, subframe, and front sprocket and found this.
You can see the ball bearings piled at the bottom and the shaft is well off center along with a nice chunk of the case chipped. (We do have the chipped piece.) Hopefully we can tig weld it back on. We'll split the cases tomorrow evening and see what the damage is. I'll have pics for anyone who has never split their cases.
Old 07-13-2006, 09:48 PM
Aus_Rider_22's Avatar
Mod From Down Under
Default Re: CRF250R Tranny Puzzle
My fingers are crossed you don't find anything ugly in the bottom.
Good luck David
Old 07-13-2006, 09:55 PM
crfjedi393's Avatar
Obi Wan Kenobody
I'm sure it will be ugly. However, I'm pretty sure the crank and all is good. It looks like just a transmission problem at this point. We'll find out the extent of the damage tomorrow.
Old 07-13-2006, 10:17 PM
I've been RM-Zedded
Last Online: Today 03:53 AM
Ouch!!! I don't think those bearings are supposed to be like that
Good luck with that Jedi, and may the force be with ya'll!
Old 07-13-2006, 10:23 PM
Vintage Dave393's Avatar
ATM History Professor
My wallet hurts just looking at that.
Might be time to look for a spare engine on Ebay that has a blown top end so you can have a parts donor. Something tells me you are gonna need serious parts.
Old 07-14-2006, 09:53 AM
Last Online: 08-20-2006 03:49 PM
with that countershaft bearing going the way of the chain i'd suspect the chain was too tight!!! Well the bottom end on these things are pretty simple i hope everythign looks good inside (besides bearings)
Old 07-14-2006, 10:13 PM
crfjedi393's Avatar
Obi Wan Kenobody
We didn't get as far as we wanted this evening. Patience and time both running short. We got the engine out and we will worry about splitting the cases tomorrow evening. jr and I are just fumbling our way through this deal. rbm33 has the knowledge but he has his own bikes to work on. Getting the engine out was hard enough. I dread putting it back in.:
BTW, c91x. No deal on the chain being too tight.
Old 07-14-2006, 10:32 PM
Big Maico 393's Avatar
Super Moderator
Last Online: 11-19-2009 02:20 PM
Jedi:
When you get the motor apart, if you want to save the broken case. I know a guy that should be able to save it if that's the only broken part.
This guy is so good that American Honda had him do warrenty welding work!
Let me know & I'll talk to him, he's also a rider/racer.
Old 07-15-2006, 06:47 AM
Satch0922's Avatar
yes...I agree....a YZF engine!!!
Old 07-15-2006, 06:50 AM
Satch0922's Avatar
Yeah....looks pretty loose to me
Sorry...just inflating my post count to get to 9000.....at the expense of Jedi. I apologize.
Old 07-15-2006, 06:57 AM
Satch0922's Avatar
JEDI>......check your pm's
Old 07-15-2006, 11:21 AM
MotoMan's Avatar
Floppy
Last Online: Today 08:39 AM
Ouch...all I see is dollar signs man.
Just take your time with the dissasebly...it's pretty simple.
If you run into anything, just post man, that's what we here for.
Old 07-15-2006, 01:34 PM
crfjedi393's Avatar
Obi Wan Kenobody
We're gonna get the cases split and see exactly what we're dealing with before we make any decisions.
I may take you up on that offer, Big M. But it may be something rbm can do for us.
jr. has to work 'til dark tonight so we will start on it again tomorrow.
And thanks for the info, Satch.
Old 07-15-2006, 08:19 PM
kuritaro9's Avatar
might consider BIG BLUE
i called a buddy of mine that is a mechanic for team HRC, and he said it is definatly caused by a chain being too tight... he said follow the manual as close as you can for the chain slack...
Old 07-15-2006, 08:32 PM
crfjedi393's Avatar
Obi Wan Kenobody
Not even worth responding to.:
If the chain was too tight it is because a rock or something got between it and the sprocket.
Moving on........
Old 07-15-2006, 08:42 PM
kuritaro9's Avatar
Moving on........
thats possible.
Old 07-15-2006, 08:46 PM
crfjedi393's Avatar
Obi Wan Kenobody
rbm33 and I got about an hour and a half to spend on the engine this evening. jr. was working but I wanted to get as far as we could and see what we were facing. Got some pics.
We removed the head, ignition cover, flywheel, cylinder, and kick starter.
We removed the clutch cover. The clutch assembly comes off after bending down the little tabs around the nut.
The water pump was a little bit of a problem. The cover came off easily but the impeller proved to be pretty stubborn. It turns out this little rascal has a "left-handed" thread.: An impact wrench, a dead-blow hammer, and everything else we could think finally convinced us to go the opposite direction. We got it off but we sure buggered up the shoulders. We finally removed the piston and placed a ratchet in the ring at the top of the rod for a back up.
More pics and the rest of the story to come later.
Old 07-15-2006, 08:51 PM
Macho393's Avatar
CROSSTHREADED RACING
maybe its because the chain was too tight.....just guessing myself. What I like to do is apply a chain stretcher and really give it a go! If my bike won't roll backwards in neutral I know I did it right. My gosh man your 45 years of age and a pretty sharp person learn the basic stuff b4 you ride. As for oil I use up to 3 qts per change. I fiqure if it they say 1.2 qts then 3 must be better. You also most likely don't know squat about tire pressure either. I run the full 32 pounds. I couldn't read it on my motorbike tires so I looked on my truck tires(Those numbers are way bigger to read). Insure you also lube up your grease fittings on the brake cylinder area(they are right in front)Let me know if I can help some more.Here's my #555-867-5309
ps Dude it looks like in the pic above RPM knocked over his gatorade on your motor.
Old 07-15-2006, 09:01 PM
Satch0922's Avatar
Old 07-15-2006, 09:06 PM
i was stating the obvious ..... countershaft bearings don't just give out its from people keeping the chain too tight.
Similar Threads for: CRF250R Tranny Puzzle
2007 crf250r vs 2006 crf250r jordan_pense 4-Stroke Motorcycles - Honda 9 09-09-2007 08:55 PM
tranny Randy11023 General Discussion 7 04-06-2005 08:51 PM
Tranny oil; dirtracer_2000 2-Stroke Motorcycles - General Discussion 7 12-07-2004 07:34 AM
Tavern Puzzle cowboyona426 General Discussion 4 04-16-2004 12:21 PM
tranny oil! shiftMX General Discussion 16 02-28-2004 10:53 PM
