CRF Air Scoop/Back Fire Screen/Air Box Mod
This is a discussion on CRF Air Scoop/Back Fire Screen/Air Box Mod within the 4-Stroke Motorcycle Knowledge Base forum, part of the Motorcycle Knowledge Base category; Here's my rendition of the above mentioned mods. Air scoop mod (easiest ) Take the #er plates off the bike. ...
LinkBack (1) Thread Tools
  1 links from elsewhere to this Post. Click to view. #1
Old 04-30-2004, 02:00 AM
I've been RM-Zedded
Last Online: Today 03:53 AM
Default CRF Air Scoop/Back Fire Screen/Air Box Mod
Take the #er plates off the bike. and remove the scoops.
Old 04-30-2004, 02:01 AM
I've been RM-Zedded
Default BackFire Screen
Now to the Backfire Screen (close second on ease)
I did all these mods when cleaning my filter so it would be easier since I'd have it all apart then anyway.
Once the filter is off bend the tabs off the filter cage, then you'll see some little tabs that hold the filter in around the edges, just wiggle her out. On the '04 models, the tabs I've circled don't exist so don't spend much time looking for it if you have an '04.
I've been RM-Zedded
Default AirBox Mod
Ok, first off, no comments on what a mess my bike is... when I was all done I did clean all that crap up so it looks a lot better now.
I found that taking the rear fender off and going at this from the back side was the easiest. I also found that using a torch to heat up the blade I used to cut the plastic saved me a lot of time. it cut through the plastic like butter.
First take an un-heated (if you do in fact heat yours) and make lines where you want to cut. Then heat the blade and cut it off. If you don't use heat, simply go over and over the same cut spot until you've cut through it.
As you'll see it did a pretty clean job of cutting.
Notice my handy torch
From the back
From the side
Front view
Old 04-30-2004, 04:26 AM
BigDad's Avatar
Last Online: 05-14-2006 08:46 PM
Default re: CRF Air Scoop/Back Fire Screen/Air Box Mod
This is the best I've seen it explained. I can attest to the effectiveness of this mod. I did it a while back and there is a noticeable improvement in power. That's saying a lot, because I'm not that good of a rider and probably wouldn't notice insignificant gains. Very nice FREE gain in horse power.
Old 04-30-2004, 04:58 AM
I've been RM-Zedded
Thanks BigDad, That was my aim... Hoping to make it easier for the next guy. Pretty easy mods to begin with, but still nice to have it laid out for you.
Old 04-30-2004, 07:14 AM
VET393's Avatar
2007 CRF250X
Last Online: 11-19-2009 01:16 PM
I did this same thing almost the same way. Great cheap mod I would say.
Old 04-30-2004, 02:33 PM
smithers's Avatar
Old Desert Rat
Last Online: 11-14-2009 07:44 PM
Id probably do all those mods except the air filter screen...Ive heard its not a good idea in case theres a backfire...havent seriously put thought to this yet or test fired my airfilter to see if it would explode.
Old 04-30-2004, 02:44 PM
huffdaddy70's Avatar
Last Online: 07-10-2008 07:49 PM
Great write up Woody!
Old 04-30-2004, 04:36 PM
Frakke's Avatar
Last Online: 10-01-2007 03:29 PM
Great write up Woody!! Did you change something to the jetting?
Old 04-30-2004, 04:50 PM
strykmaster's Avatar
Wave Riding Moto Man
Last Online: 10-29-2005 10:05 PM
Wow Woody, that was a great write up. And to those who are afraid to remove the backfire screen.......don't be. It's not a problem. The only reason the manufacturers put them in there is because of liability. Not because there is a problem with these bikes backfiring. Honestly, has your CRF ever backfired? Mine hasn't. Remove it and gain a 30% increase in airflow. You're motor will love it. If you're nervous get a flame retardant air filter and use No-Toil.
Old 04-30-2004, 05:47 PM
smithers's Avatar
Old Desert Rat
I think I will do that this weekend...I need to get a new air filter also..mines not lookin so good around the wing-nut area. That was an excellent write up Woody...sorry forgot to tell ya that earlier.
Old 05-01-2004, 07:06 AM
Mainjet2001's Avatar
Last Online: Yesterday 01:06 PM
Woody.......
You did an excellent job with the instructions and pictures.
Thank you.
Um...you could be our new ATM technical illustrator.
Old 05-01-2004, 07:17 AM
I've been RM-Zedded
LOL, New Illustrator? Just doing what I can to help.
Old 05-01-2004, 08:54 AM
MotoMojo17's Avatar
Pinger-Slinger
Last Online: 09-04-2009 12:37 PM
if you do that, just in case, you would want to think about one of those fire proof air filters...when you crank four strokes it is not uncommon to see them belch a flame or at least BOOM backfire
Old 05-03-2004, 12:22 PM
Deano249f's Avatar
3 stroker
Last Online: 01-06-2009 10:34 AM
grabit re: CRF Air Scoop/Back Fire Screen/Air Box Mod
Can it be done on the CRF250R?
Old 05-03-2004, 11:50 PM
I've been RM-Zedded
Don't know why not...
Old 05-04-2004, 12:59 AM
Roostman's Avatar
"Roostman, lays an egg!"
Last Online: 04-17-2009 03:59 AM
Thats good stuff for you four strokers. And if your really worried about the firescreen, drill a bunch of 1/4 or 1/2" holes in it and youll at least have some protection and gain a descent amount of air flow. Just a thought.
Old 05-04-2004, 02:40 AM
I've been RM-Zedded
Not a bad idea roostman.
Old 05-11-2004, 07:04 AM
AndrewPA's Avatar
On the Moon
Last Online: 07-14-2009 09:03 AM
Woody, I am sure this is detailed somewhere but what were YOUR thoughts on the mod, did you notice the power gain or different characteristics. Also, any jetting changes?
Thanks
Old 05-12-2004, 11:58 PM
I've been RM-Zedded
I thought it made a difference.
What it did, based off the seat of my pants, is made the bike a lot more ... hmmm... can't think of the word to describe it.. mean??? in the mid on up.
Tags
air box mod, air scoop mod, back fire screen mod, crf mod
LinkBacks (?)
LinkBack to this Thread: http://www.allthingsmoto.com/forums/f-13/crf-air-scoop-back-fire-screen-air-box-mod-11430/
Posted By For Type Date
CRF Airbox / Back fire Screen Mod - Details - This thread Refback 09-09-2008 01:00 AM
Similar Threads for: CRF Air Scoop/Back Fire Screen/Air Box Mod
Mis-fire / back-fire, wont kick start donzi1971 2-Stroke Motorcycles - Honda 1 11-16-2008 03:46 PM
Someone scoop this deal up QUICK! cowboyona426 General Discussion 7 07-05-2006 11:55 AM
back fire MGilbert 2-Stroke Motorcycles - Kawasaki 7 09-09-2004 11:42 PM
back fire??? BigGuynMI Misc Riding Types 11 12-01-2003 11:56 AM
cr-80 1994 side panels/ radiator scoop Zornpanzer 2-Stroke Motorcycles - Honda 1 09-21-2003 01:03 PM
