4-stroke Valve Shim Calculator (Excel)This is a discussion on 4-stroke Valve Shim Calculator (Excel) within the 4-Stroke Dirt Bike Knowledge Base forum, part of the Dirt Bike Knowledge Base and Build Threads category; I have had these located on the portal for literally years, and for some reason no one knows they are ... |
| I have had these located on the portal for literally years, and for some reason no one knows they are there, so I'm moving them here. See attached: 4-Stroke_Valve_Shim_Calculator_Instructions.doc & 4-Stroke_Valve_Shim_Calculator_Rev2.xls These two documents make figuring out what shim you need to get your valves back in to spec. a breeze. Hopefully these will get a little more exposure and help more peeps. Last edited by Woody_393; 07-27-2008 at 01:29 AM. |
| unable to get the yellow cells to change values. Looks like a GREAT program. What am I doing wrong? |
| I just downloaded it again to see if I could duplicate what you are seeing, and I'm having trouble getting to not work. Can you be more specific about what isn't working? You enter a value in the yellow field and hit enter, and it simply changes back or it won't let you type in it at all? |
| cant type it in at all. I highlihgt the cell but can not type in a new value.........Steve |
| What version of Excel are you using? It almost sounds like you don't have excel, but maybe just a viewer? |
| You are absolutely correct, silly me |
| If you want you can download openOffice which will open it and let you use it. www: OpenOffice.org - The Free and Open Productivity Suite It's free. |
| Very nice. Thats way easier then what was done in the barn that night you were there woody. |
| You can say that again. Once you've done it a couple of times, you really don't need it, but I can tell you when I first started shimming, this thing was a gift from above. |
| Will that chart work for a YFZ if you changed numbers or just Honda? I went back to look at it agian but it was in use. |
| still in use? That usually means you still have it open. I think the quad has the same valve specs as the bike so yes it would work just fine. |
| OOOPS! My bad! |
| Tags |
| valve shim calculator |
Similar Threads for: 4-stroke Valve Shim Calculator (Excel) | ||||
| Valve shim help | madcow393 | General Discussion | 3 | 04-12-2005 10:19 AM |
| Valve Shim Guides | Rockey | 4-Stroke Dirt Bike Knowledge Base | 1 | 06-20-2004 05:17 PM |
| Valve shim availability????? | Ranger_450F | General Discussion | 6 | 04-24-2004 03:13 PM |
| Excel based gearing calculator | kimconnor | 2-Stroke Dirt Bike - Kawasaki | 7 | 07-07-2003 01:40 AM |
| Valve shim Calculator from TT | Woody_393 | 4-Stroke Dirt Bike - Yamaha | 2 | 01-30-2003 07:36 PM |
