All Things Moto! Web Forums
Go Back   All Things Moto! Web Forums > Specialty Riding Forums > Vintage Riding
NEED HELP...82 yz490 throttle stuck wide open
This is a discussion on NEED HELP...82 yz490 throttle stuck wide open within the Vintage Riding forum, part of the Specialty Riding Forums category; I'm still having problems with the throttle going to wide open with the throttle in idle position. I've changed out ...
Old 10-12-2009, 10:57 PM
mkpack77's Avatar
Last Online: 10-13-2009 12:33 AM
Usflag NEED HELP...82 yz490 throttle stuck wide open
I'm still having problems with the throttle going to wide open with the throttle in idle position. I've changed out the crank seals, looked over the system and taken the carb apart and everything looks fine. Could it be the jets in the carb?? Any help would be appreciated.
Old 10-12-2009, 11:10 PM
kwmotocrosspunk's Avatar
Im SOUNDERS Till I Die!
Last Online: Yesterday 05:44 PM
so when the bike is idling, is the idle raising itself to wide open?
if thats it, check your throttle cable, make sure it is well lubricated, not kinked or has any harsh bends or breaks, also make sure it is routed correctly as per the manual
Old 10-12-2009, 11:18 PM
mkpack77's Avatar
Usflag
yeah from idle it shoots full open, the cable is new and run properly. I can tell that the slide and cable are working because you can hear the slide hit top and bottom, so it's moving correctly with the throttle input. It's just that it doesn't matter where the throttle is, it goes full open. And that's what doesn't make since to me, how can it go full open with the slide full down/ in idle????
Old 10-12-2009, 11:28 PM
2strkyz's Avatar
Last Online: Today 09:50 AM
Check for a leak between the carb and the motor.
Old 10-12-2009, 11:31 PM
oh ok, than you most likely have an air leak, either on the carb side or the engine side of the intake boot, since it is idling so high you can try taking a spray bottle filled with water, while its running, spray some water all over the intake boot(both sides), this should drop the idle(possible kill the engine but shouldn't hurt anything) if it does that take off your intake boot and check the sealing ability on it, check for cracks or tears on both sides, you might have an o-ring on the engine side which could be worn out and allowing air into the motor
Old 10-13-2009, 12:32 AM
mkpack77's Avatar
thanks, I'll have to try that tomorrow
Old 10-13-2009, 03:35 PM
Last Online: 11-02-2009 04:01 PM
Just the thought of a yz490 2-stroke with a throttle stuck wide open sends a shiver down my spine!
Old 10-13-2009, 08:15 PM
merlyn1965's Avatar
Last Online: 11-01-2009 09:26 AM
Check your boost bottle and the hose going to it, they do crack sometimes. Easy fix if it is.
Old 10-13-2009, 09:03 PM
Yep, especially nasty in the middle of the forest with a few hundred trees about...:hair raising
As to the original Q, look for leaks as described in earlier posts, and look for little burrs on the slide or inside the carb.
While the motors running, the slide gets sucked towards the engine, any nicks, ridges or free play on either the slide or carb body can cause a hang up.
That's why modern 4 strokes have 2 cables- push pull- no lawsuits..
BTW, rode/raced an 84 IT490 for 10 years..
Similar Threads for: NEED HELP...82 yz490 throttle stuck wide open
82 YZ490 throttle stuck full open mkpack77 2-Stroke Motorcycles - Yamaha 10 08-02-2009 02:31 PM
89 YZ 250 WIDE OPEN ON KICK. dc6587 2-Stroke Motorcycles - Yamaha 5 06-30-2009 02:03 PM
2001 kx 125 bogs when cracking it wide open sinisterkx 2-Stroke Motorcycles - Kawasaki 6 10-24-2007 03:17 PM
01 kx250 starts but stuck wide open TeamGreen2323 2-Stroke Motorcycles - Kawasaki 6 07-03-2007 12:25 PM
Wide open Austin225 General Discussion 2 05-14-2004 04:33 PM
