Old 03-15-2016, 04:12 AM
Last Online: 05-19-2016 09:04 PM
Default Yz125 cluth problems 1998-the cover !!!
I need help. I have replaced my clutch in my 125/assembly is in there correctly..double checked everything. Get to putting the clutch cover back on and i'm not able to mesh the rod on the cover and the push rod gears properly. Either clutch is too mushy or too tight when i attach cable. brand new cable and perch. took lever off the top of the rod on clutch cover and tried to get mesh right then put lever back on in proper alignment marks on bike. Still can't get it right? Is there a trick to this? Help!!!!!! thanks
Old 03-15-2016, 07:25 AM
Last Online: Today 08:14 AM
AS I recall, there should be a mark on the cover indicating where the arm should be positioned as you install it. The arm will then move to the correct position when the cover is fully installed.
Also you clutch cable should have the adjuster at the handlebar lever as well as one in the cable between the lever and the arm that can also be adjusted.
Old 03-16-2016, 07:09 AM
wFo250's Avatar
will fall over
Last Online: 03-20-2019 07:17 AM
The 'trick' is to make sure to apply plenty of mechanical aptitude during install. After that, it goes together easy
good luck.
Old 03-16-2016, 10:14 AM
Put the cover on. Then remove the arm from the rod and line it up. The manual will show you exactly how to do it.
Similar Threads for: Yz125 cluth problems 1998-the cover !!!
88 CR125 Clutch Cover problems/replacement CRSparky 2-Stroke Dirt Bikes - Honda 2 04-12-2015 09:31 PM
1998 YZ125 Clutch Cover problems jeffreyinva69 2-Stroke Dirt Bikes - Yamaha 15 09-17-2014 07:23 PM
yz125 cluth problems 1998-the cover jeffreyinva69 General Discussion 0 09-11-2014 01:17 PM
01 YZ125 Crankcase cover deuscent 2-Stroke Dirt Bikes - Yamaha 0 07-03-2009 06:16 PM
1998 kx 80 problems? ripper 3 2-Stroke Dirt Bikes - Kawasaki 4 11-19-2004 05:18 PM
