Old 02-25-2019, 09:31 AM
Last Online: 02-25-2019 09:31 AM
Default Yamaha 4 stroke oil change gone bad?
My wr400f dipstick reads full after draining .. 2 reservoirs wtf? Anyone Please Help??
Old 02-25-2019, 04:38 PM
Last Online: Today 06:16 AM
If you did not warm it up prior to draining the oil, you can have this.
Old 02-28-2019, 05:31 AM
There are two bolts that need to be removed. One on the engine, the other is at the lower front of the frame down tube, facing the front fender.
Also, there's a metal strainer located on the bottom of the down tube, it should be cleaned periodically. It has a tube attached to it- do not try and remove the strainer by bending the tube out of the way to get clearance, you'll wind up damaging the tube. Loosen both ends of the tube and remove it before removing the lower strainer/screen. Be warned- It's real easy to damage the tube and a pain to get the O ring seated properly when re-installing, if your in doubt about tackling the screen, don't do it.
A Yamaha owners manual explains it in detail.
https://www.yamahapartshouse.com/oem...bc78e40e/frame
Part #4 is drain screw, #2 is strainer/filter
Similar Threads for: Yamaha 4 stroke oil change gone bad?
Yamaha 2005 wr450f Watery Oil Change Chunai143 4-Stroke Dirt Bikes - Yamaha 4 05-03-2016 10:44 AM
Yamaha TTR 600 oil change question kristjangh 4-Stroke Dirt Bikes - Yamaha 0 01-20-2013 09:04 AM
how much will a change in elevation effect my 2 stroke? rockwarrior5 2-Stroke Dirt Bikes - Honda 9 08-04-2011 05:44 PM
2 Stroke oil change IM22SNIPER 2-Stroke Dirt Bike Knowledge Base 4 12-16-2008 03:18 PM
Yamaha YZ250F Top End Change Keetoman393 4-Stroke Dirt Bikes - Yamaha 3 10-24-2005 08:29 AM
