What kind of torque wrench should i get?This is a discussion on What kind of torque wrench should i get? within the General Discussion forum, part of the Dirt Bike - ATV - Suspension Forums category; Well i got thinking about tools and i was wondering why i don't have a torque wrench yet. What kind ... |
| Well i got thinking about tools I am kinda wanting a "Break away" type with Newton meters and ft/lbs and in/lbs. What kind do you guys recommend? |
| I have the craftsmen digitorque.It gos down to 25ft lbs so it may not be the best for dirtbikes. I got a cheaper one for working on the bikes and when i get home i'll see what it is. |
| Oooo, a digital one would be sweet blue. I have drooled over those in Sears many times. I have one of the kind that pops and a meter. The meter type are nice when you don't have a manual and you need to know what the torque is when you loosen a bolt. But for all other situations the pop type is alot nicer IMO. |
| Yeah i want the break-away type, where after the torque is reached, it just goes limp you could say. |
| I got the Crafstman pop type on sale for $50. It has ft lbs. and meters. Seems to work pretty well. |
| Mototman Here is the icing on the cake.I got it for nothing. |
| all the case bolts that are 8mm heads are only 8ft/lbs. get a smaller one that is calibrated in inch pounds. |
| 50$ isn't bad at all. Does it go down to 8ft/lbs like yardpro mentioned? |
| Yep the 1/4" drive will measure in inch pounds I believe. Blue, that is really cool man. Those suckers run around $90 new!! |
| yep the 1/4' ones do. i never use a torque wrench in the bigger bolts ( except head bolts). i just crank em tight. the small ones are easy to strip, so if you're new to wrenching then use the smaller torque wrench. after a while you will develop a feel for when the bolt starts to stretch. |
| I have a Craftsman beam type 1/2 drive torque wrench that I really like- I'm not sure what it cost because Florida393 bought it for me for my wedding |
| What kind of wrench to use? | daveythewavey19 | General Discussion | 7 | 12-04-2006 10:32 AM |
| torque wrench | Red Rider 943 | General Discussion | 6 | 05-03-2005 10:52 PM |
| torque wrench | crdemon | Wanted Items | 2 | 05-16-2004 09:02 PM |
| torque wrench | dirtrider1 | General Discussion | 21 | 04-16-2004 11:31 AM |
| torque wrench | shiftMX | General Discussion | 19 | 02-13-2004 08:16 AM |
