Old 05-01-2011, 08:56 PM
Last Online: 08-05-2011 09:37 PM
Default Water Pump 2003 CR 250
I just bought an 03 CR 250 the guy put a new cylinder and head. Looks like he took the right side cover off completely because all the gaskets are new. The pump is sipping out through the weep hole on the the case cover. I took the pump cover off and the impeller moves when you turn the bike over.
Does any one know if it could be the seal or the water pump is out. Its dripping just like a car water pump when they go bad.
Old 05-02-2011, 03:18 AM
crdude's Avatar
Missing the days of riding
Last Online: 11-26-2018 06:05 AM
If it is leaking from the weep hole, them its time to rebuild the coolent pump.
If its like my old 96 cr, then you will have to remove the casing that the coolent pump is in which is also around the clutch, so be sure to drain your oil before removing it.
I used a 3/8" impact to remove the nut from the shaft. Then replace both seals and the bearing & reassemble.
IIRC the seals, bearing and gaskits costed around $40.
Old 05-02-2011, 08:05 AM
Last Online: 08-09-2012 08:45 AM
This, with the exception of the impact. The water pump shaft should have a flat spot on the opposite end of the impeller that you can grip with a wrench.
Old 05-03-2011, 04:58 PM
crdude's Avatar
Mine was so tight that even with vice grips on the other end I couldnt get it to come apart. Impact was the only want to get mine off, I guess the last person that was in there probably tightened it down a bit to much.
Old 05-04-2011, 03:05 PM
Last Online: 08-04-2011 03:42 PM
Usually if it is leaking out of the weep hole that just means that the seal behind the water pump is bad. My YZ has a similar set up, all I had to do was take the impeller off, replace that seal and the problem was fixed.
Similar Threads for: Water Pump 2003 CR 250
93 cr250 water pump kmaxwell 2-Stroke Dirt Bikes - Honda 3 02-09-2011 03:20 PM
2005 CR250 Water pump releasing water benkm108 2-Stroke Dirt Bikes - Honda 4 01-05-2010 08:14 PM
250F leaking water from bottom of water pump lsqrus 4-Stroke Dirt Bikes - Yamaha 2 09-09-2007 01:05 AM
rmz 450 water pump casey392 4-Stroke Dirt Bikes - Suzuki 1 08-30-2005 06:23 PM
KXF/RMZ 250 Water Pump/Oil Cover Fix factory General Discussion 5 10-31-2003 05:59 AM
