turning: Right or left?This is a discussion on turning: Right or left? within the General Discussion forum, part of the Dirt Bike - ATV - Suspension Forums category; I was just really curious about this, I figure it's alot easier for me to turn to the left because ... |
| I was just really curious about this, I figure it's alot easier for me to turn to the left because I can get to the back brake alot easier, I was wonderin about other people though? |
| YOU are not supposed to be useing the rear brake i repeat DONT use it, you are suppose to be using the front brake and have 2 fingers on the clutch at all times, so it should be easy o tur either way. |
| Really??Why the heck am I findin all this out now!everyone around here uses that, but I'm tryin what you said, crap, well I'm gettin on that right when i go ridin, youve been tearin me up on all the posts.....LOL |
| yeah im the bigg daddy, hey meet me in the chat room dude |
| alright |
| your supposed to use both brakes at the same time |
| nope just the front man |
| Well it depends! Yes you should always use you front brake but you are also supposed to use the rear brake with it, if you dont you cant stop as fast without making the front end lock up and slide out. When you are turning you shouldnt be using any brakes at all because all braking should be done before entering the turn. |
| There are many different riding styles...I think finding your own from practice then encorperating tips you get is the best style. |
| the pros say that you dont even need a front brake...and for me i use the front brake 95% of the time, the other 5% is back and front at the same time. (if i want to stop fast Off-road) |
| I also find turning left easier. It's manily because the throttle is on the right....gives me better control. It's just my personal opinion. When riding you want to concentrate the majority of your braking power to your front wheel. However, it is fun to come ripping into a corner and use the back brake to pitch the bike out. Plus, who doesn't love a little skidding action? |
| So you guys that use the front brake are you telling me you don't use the nacl brake at all during the corner??, I go into the corner real hard 3/4 of the way throughI tapp the back brakes and then I drop the clutch Last edited by tons_of_fun; 07-29-2004 at 11:12 AM. |
| I mainly use the front brake as well. Just seems easier to get at while cornering. 'Course...I am DANG slow at cornering. I will try the breaking before cornering suggestion...sounds like a solid technique. I also try to look at the end of the turner, rather than staring at the ruts in front of me. Oh, and weight the outside peg. Those two things seemed to get me from SUPER-MEGA slow to just MEGA slow cornering |
| I should be fine after I learn to turn right, i just can't do it |
| I'm a woods racer... we use both depending on the type, grade and radius of the turn. |
| i prefer left turns...i donnio why. You would think with what i have it would be equal either way, but i cant turn worth crap to the right....... |
| Wow, lots of bad info in this one... Sorry, but the front brake is pivital if you are ever going to be fast, AS is use of the BACK.. Correct braking technique is to use both front and back at the same time. The key is to finish your braking BEFORE you turn (read before the apex of the corner), then be on the gas, as you are turning. As Keeto mentioned, different situations call for different use, but as a general rule, you will use both most of the time and a combination of either the rest. 70% of braking power comes from your front brake, so use it (their are situations that call for not using it, but as a general rule, the front brake is your friend). If someone told you "I know how you can get 30% better braking power." Would you want to know how? Me too. The answer is using the back brake in conjunction with the front. Learn to use it, without locking it up. You should get comfortable using the back brake regardless of turn direction. I would suggest practicing the circle drill (in both directions) and the figure 8 drill. Both will help you with turns. For me, I've never had a problem in either direction. I'm slow both ways. |
#18
| I need to work on my front brake control period then cuz I can't get into a right for crap, I think the best peice of info, is to do it how u can do it the fastest |
#19
Set up a slalom (sp?) course in an open field, and the further to the end you get, the closer the obstacles become. That should really help since you'll hit your obstacle if you mess up, which you dont wanna do. Maybe i should try that..... |
#20
| You remind me of one of those kids that doesn't get good grader they're just really smart, and they always have their own opinion |
| 01 cr125 turning into a 02+ cr 125? help | 2001hondacr125 | 2-Stroke Motorcycles - Honda | 3 | 01-30-2008 12:50 AM |
| Turning Advice(vid) | Adhd Matt | Motorcycle Riding Tips | 11 | 01-08-2008 10:00 PM |
| best turning 250F | joe346CBMX | 4-Stroke Motorcycles - General Discussion | 9 | 08-20-2007 11:42 PM |
| ATM turning to quads? | schwen_108 | General Discussion | 93 | 08-11-2007 03:17 AM |
| OT- Cox Household Turning Into Zoo! | DCox | General Discussion | 17 | 01-05-2005 06:41 AM |
