Quantcast Tire Pressure???
All Things Moto! Forums AMSOil - ATM Fantasy Sponsor
Go Back   All Things Moto! Forums > Dirt Bike - ATV - Suspension Forums > General Discussion
Tire Pressure???
This is a discussion on Tire Pressure??? within the General Discussion forum, part of the Dirt Bike - ATV - Suspension Forums category; Hi, I was wondering if anyone knows, or knows where I could find out a good tire pressure to run? ...
Old 07-24-2008, 12:57 PM
Last Online: 08-25-2008 01:00 PM
Thumbs up Tire Pressure???
Hi, I was wondering if anyone knows, or knows where I could find out a good tire pressure to run? I know that necessary pressures will vary but Im not quite sure where to begin. I also weight about 190 lbs. if that matters..
I have a 2001 CR125 and on the rear tire it reads:
Dunlop Sports K695 110/90-19
on the front it reads:
Dunlop sports K490 G 80/100-21 51M
Any advice welcome,
Thank You
Old 07-24-2008, 01:02 PM
I've been RM-Zedded
Last Online: Today 04:31 AM
Default Re: Tire Pressure???
Depending on if you ride off-road, sand dunes, or Motocross it might be different.
But the range is 10-15lbs.
Old 07-24-2008, 01:19 PM
Im mostly just riding off road, but thats really all just 10PSI-15PSI?
Old 07-24-2008, 01:22 PM
I've been RM-Zedded
Yep that's it.
For off-road, I'd stay closer to the 15lbs mark.
Old 07-25-2008, 02:24 AM
Last Online: 09-01-2008 12:43 PM
i think of all things on the bike im most picky about the tire pressures. mx pressure would put me flat on the floor offroad!
Old 07-25-2008, 03:32 AM
bronc3's Avatar
Last Online: 09-02-2008 04:44 PM
Riding mostly sand down here, I generally run 12 in the front and 8-10 in the rear. HD tubes and rim locks. D'lop 773 front/756 rear on the YZ 250, Kenda Trackmaster II rear/ 777F DOT front on the DRZ 400. I run slightly more pressure in the DRZ's tires.
Old 07-25-2008, 03:46 AM
I've been RM-Zedded
I am very picky too. The thing to remember about off-road motorcycle tires is that due to the low pressure (10-15lbs), even 1 lb is close to a 10% change, which when you look at it like that is quite a bit. The difference between 15lbs and 12lbs is huge percentage wise.
So yeah, I'm picky too, and I always check my tire pressure before riding.
Old 07-25-2008, 07:09 AM
Big Maico 393's Avatar
Super Moderator
Last Online: Yesterday 06:07 AM
Another thing that yo have to consider is the sidewall of the tire, some of the tire have a stiff sidewall (Maxxis) & you need to adjust somewhat for that to get the proper "feel"
I know that there is a huge difference between the Dunlop 756F front tire that I was running & the Maxxis I.T. that I put on the front of my Maico, I'm going back to a soft compound front tire! I just get a better feel from the front end.
Old 07-25-2008, 07:21 AM
pragmatic393's Avatar
..Thats, Mr. Spode to you!
Last Online: 09-05-2008 06:13 AM
Good point, Wood! With that said, I would look into the proper pressure guage..low range with a max of around 30psi.
Old 07-25-2008, 02:36 PM
I've been RM-Zedded
Agreed completely on a good guage. All the ones I've found and own only go to 18 or so lbs, and accurace is key.
I had one for a while that I used and my buddy with his digital one checked my tire pressure and I was running 18 or so, and my guage showed 14 Shortly after that I went out and bought a good one. I'm on my second good one now.
Old 07-25-2008, 07:18 PM
Drew778's Avatar
2 Stroker 4 Life!!!
Last Online: 09-05-2008 08:41 PM
I run 11lbs cold in the front and back, it seems to work pretty good.
Old 07-25-2008, 10:09 PM
kschilk's Avatar
What...me worry?!
Last Online: Today 07:20 AM
Tire size and composition makes a difference too, as well as rider weight. I'm light (5'8", 135 lbs) and run a 5.30/18 rear, on my CR480. Though it usually comes out at around 8-10 psi, I never start with a tire gauge. I adjust my tire pressure by the same method I adjust my suspension...with a stopwatch. Looks, feel and even gauges can be deceiving but time never lies.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: Tire Pressure???
tire pressure oppo General Discussion 3 05-31-2007 06:04 AM
Tire Pressure Gauge FixingStuff General Discussion 7 02-06-2007 11:32 AM
Tire Pressure Help Whiiterabbitt 2-Stroke Motorcycles - Kawasaki 12 11-20-2006 04:50 PM
tire pressure jocww General Discussion 10 06-16-2005 06:18 PM
tire pressure atreyu General Discussion 2 01-10-2004 01:39 PM
Portal Forums ATM! Online Store Photo Gallery Moto Garage RSS Feeds ATM! Link Directory Today's New Users
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright ©2002-2008, All Things Moto! Inc. All Right Reserved.
Page generated in 0.21478 seconds with 12 queries
