tire mounting problemsThis is a discussion on tire mounting problems within the General Discussion forum, part of the Dirt Bike - ATV - Suspension Forums category; I am a new dirt bike owner but a long time mechanic. I have just finished my first attempt at ... |
| I am a new dirt bike owner but a long time mechanic. I have just finished my first attempt at mounting some new tires on my cr250. I am having the same problem on both of them. One spot on a single side isn't completely seating the bead against the rim. I took them both up to 30 #s. Both areas not seating are around the valve stem I'm not sure if that matters. Any help would be greatly appreciated thanks in advance |
| is it not seating around the valve stem or the beed lock?...also make sure you use a little soapy water around the rim and tire so it can slide in and seat .... |
| Getting the tires warm sometimes helps. And sometimes I would bounce them (straight up and down like a basketball) around trying to hit the unseated spot on the ground. |
| Don't be scared to pump them up to 70psi to seat them, then back them off to 13-14psi. |
| I just got back on and finally found my own post, sorry I'm not exactly an expert forum user yet. Thanks for all the help, I finally just pumped 60 pounds in it and left it for a few hours and they both just slowly crept onto the shoulder. It was kinda weird, I have mounted lots of other types of tires and never seen anything like that before. Thanks again for the info JOHN |
| wd40 around the bead then pump to 40 psi and whamo! |
| wouldn't wd40 be a bad idea to put on a tire it's an oil and oils break down rubber??? |
| Tags |
| mounting, tire, wheels |
Similar Threads for: tire mounting problems | ||||
| Helmet action Camera advice for ATV / handlebar mounting? | atvbull | ATV/UTV - General Discussion | 0 | 05-08-2008 05:37 PM |
| Mounting hour meter | cowboyona426 | General Discussion | 16 | 03-09-2006 08:41 PM |
| Tire problems. help please | RmZuzuki | 4-Stroke Dirt Bike - General Discussion | 1 | 05-13-2005 05:11 PM |
| Mounting Handguards | mtk | General Discussion | 5 | 03-22-2005 05:48 AM |
| 50 tire | ridered2 | Misc Riding Types | 4 | 02-11-2005 12:31 PM |
