![]() Feeling cramped comming into turns I am 6ft 4 225lbs Im on a 2001 yz250 what is the tallest seat I can get ? I have a tag top clamp and tag t 2 cr high bars and getting arm pump bad any sugestions would help. |
![]() Moved from KB to the General Discussion forum for better exposure. |
![]() sdg makes the tallest seat. on the yz you can flip the footpeg mount and lower it a bit. also get some bar risers. i have +10mm risers and it helps a ton |
![]() yp393 thanks for the help I will try the sdg seat and peg mod |
![]() Quote:
![]() 04 whyzee I looked at my pegs today and it looks easy just take them off cut off the lower spacer on the peg then place the spacer on top of the peg switch the peg spring from the right side to the left and slide the pin back in .Ithink I will ride it for a while before I tig weld it. |
![]() What would I have to TIG weld? The spacer? The peg? I'm a bit confused. |
![]() They say you dont have to weld any thing, the piece on the bottem of the peg that the pin goes through gets cut off and moved to the top of the peg then you install springs and pins Last edited by bermshot250yz; 11-30-2003 at 10:38 PM. |
![]() I guess if I screw it up I can always just buy the spacer again or make my own. I'm just a little learing off cutting up anything on my brand new bike. |
Thread Tools | |
Seat or Pan | Kawboy67 | 2-Stroke Dirt Bikes - Kawasaki | 0 | 04-24-2009 10:13 PM |
07 seat on an 02 | telecasterjoey | 2-Stroke Dirt Bikes - Honda | 3 | 10-17-2008 09:45 PM |
seat height help | Davidttr | 2-Stroke Dirt Bikes - Yamaha | 2 | 04-24-2005 10:10 AM |
Fix for seat rip? | Woody_YZF | General Discussion | 16 | 05-14-2004 09:56 PM |
CR SDG seat | madcow393 | Product Reviews | 0 | 01-09-2003 06:07 PM |
