Old 04-24-2006, 08:39 AM
yz250guy's Avatar
Last Online: 02-03-2016 11:37 AM
Default Re: swingarm/linkage bearing driver question
What do you guys think about this:
http://www.harborfreight.com/cpi/cta...emnumber=38145
Old 04-24-2006, 11:56 AM
Tdub's Avatar
Originally Posted by yz250guy
What I don't like about this kit or the socket method on needle bearings it is so easy to deform the end of the cage when "pounding" it home. The MP kit is machined to fit into the bearing thuis keeping it centered, JMO Tdub
Old 04-24-2006, 05:42 PM
Florida 393's Avatar
Semper Fidelis
I bought mine at the local Harbor Freight store, no catalog numbers to share.
Bill
Old 04-24-2006, 06:25 PM
Florida, are you referrring to a turret press. Just a rack and pinion set up vertically?
For years I used a bottle jack and a retangular piece that I welded together from 6" channel. Make some jigs and push pins and you would be surprised what you can do. Or just spend a few hundred for one the discount house 10 ton jobs. The turret press is really fast though and a good value.
I use the heat gun and my own lathed over bearing installers, which you can get at a bearing house when I change bearings. That MP one sure is impressive to hold though,,just makes you think you are going to go as fast as Reed, knowing his tuner uses one.
Old 04-24-2006, 06:41 PM
DRGSin393's Avatar
Last Online: 06-10-2014 12:42 PM
Could you elaborate on what the MP is, where it could be purchased, etc...thanks, it sounds like the way to go.
Old 04-24-2006, 06:52 PM
Tdub's Avatar
http://www.motionpro.com/motorcycle/..._bearing_tool/
They can be purchased directly from MP or from your local dealer thru Parts Unlimited. Tdub
Old 04-24-2006, 07:52 PM
Semper Fidelis
OSSAGP,
Yeah, its a turret press. Nice tool and works great for the price.
Bill
Old 04-25-2006, 11:26 AM
DRGSin393's Avatar
[QUOTE=FFRacing11x
They can be purchased directly from MP or from your local dealer thru Parts Unlimited. Tdub[/QUOTE] Thanks for the clarification
Old 04-25-2006, 11:31 AM
yz250guy's Avatar
Does the MP one work for the linkage bearings as well?
Old 04-25-2006, 11:43 AM
Tdub's Avatar
i will check when I get to work. Tdub
Similar Threads for: swingarm/linkage bearing driver question
'92 YZ250 Swingarm Bearing dt_maximum 2-Stroke Dirt Bikes - Yamaha 2 04-28-2009 02:52 PM
Swingarm bearing removal dangerSteve 2-Stroke Dirt Bikes - Honda 9 02-25-2009 04:46 PM
Shock Linkage Bearing Removal coss 4-Stroke Dirt Bikes - Honda 7 01-01-2008 08:19 PM
Fork seal driver question 04kx250 Dirt Bike Suspension Tuning 10 05-27-2007 12:58 AM
Swingarm linkage grease nate650 4-Stroke Dirt Bike Bike Forums 1 11-10-2003 05:17 AM
