stripped drain bolt
This is a discussion on stripped drain bolt within the General Discussion forum, part of the Dirt Bike - ATV - Suspension Forums category; :I recently purchased a used 00 yz426. Changed the oil and the drain plug bolt on the engine is stripped. ...
Old 03-11-2004, 01:17 PM
Last Online: 09-12-2004 04:44 PM
Angry stripped drain bolt
:I recently purchased a used 00 yz426. Changed the oil and the drain plug bolt on the engine is stripped. Any suggestions on how to fix this will be appreciated. My fear is the bolt coming out, followed by the oil and we know what will happen next.
Old 03-11-2004, 01:27 PM
Frakke's Avatar
Last Online: 10-01-2007 02:29 PM
Default Re: stripped drain bolt
I would replace that bold if I was you! If the bolt is still in the engine and you can't get it out, try with a chisel and a hammer!! Lay the bike on it's side, put the chisel against a side of the bold and give it a (not to hard) pound with the hammer (left direction) normally after one stroke the bold can be turned with your hands. Let us know if it worked ok!
Old 03-11-2004, 01:28 PM
KTM250rm393's Avatar
Hey Coach
Last Online: 05-20-2007 10:47 PM
The easiest fix is to use a time insert or helicoil which means you drill the hole the size according to the size of the helicoil/insert, then tap the threads and then insert the helicoil and then you have the same size hole. The other choice is to find a slightly larger drain plug and re-tap the hole size.
Old 03-11-2004, 01:29 PM
Need to clarify the original post. It is the alum. engine case that is stripped, not the bolt.
Old 03-11-2004, 01:30 PM
Frakke's Avatar
OOps Rick, it seems like I misunderstood the question, sorry!!!:
Old 03-11-2004, 01:35 PM
Hey Coach
Here is a post on how to fix it by using a time insert:
Here is the website for Time Inserts:
I stripped my YZ426 drain hole
Old 03-11-2004, 08:58 PM
Last Online: Yesterday 05:40 PM
Get a piggy back plug- it's a steel insert that installs in the cases and comes drilled and tapped with a new bolt so you are taking the bolt out of steel and not the soft aluminum every time.
Old 03-12-2004, 10:15 AM
Thanks for all the input. I will try to find some type of insert and hopefully be able to ride this weekend.
Old 03-12-2004, 10:35 AM
Frakke's Avatar
Let us know how it worked out and be sure to post some pics of your ride!! Have fun!!
Similar Threads for: stripped drain bolt
stripped drain plug threads 88CR250_Rider 2-Stroke Motorcycles - Honda 4 03-19-2009 10:52 PM
TTR 125 Stripped Oil Drain Bolt mnhaq2000 4-Stroke Motorcycles - Yamaha 3 09-27-2007 01:35 PM
Stripped oil drain hole..... jay123678 2-Stroke Motorcycles - Kawasaki 11 07-23-2004 12:53 AM
stripped drain plug InvolvedPatriot 4-Stroke Motorcycles - Yamaha 30 03-15-2004 12:40 AM
Stripped Oil Drain in case.... jmiakaike 4-Stroke Motorcycles - Yamaha 29 01-20-2003 05:42 PM
