Old 11-06-2003, 05:25 AM
Age is a state of Mind
Last Online: 01-18-2020 01:14 PM
Default Stipped threads - Check this fix!
TWMX has a very cool article for fixing stripped threads.
Go here to check it out.
Looks pretty cool to me.
Old 11-06-2003, 06:19 AM
Yardpro393's Avatar
Default Re: Stipped threads - Check this fix!
time serts are the ticket. they are far superior to helicoils. i have used them before with great results. the kits however are very expensive
Old 11-06-2003, 06:25 AM
VET393's Avatar
Last Online: 09-17-2013 12:07 PM
We use some similar inserts here at the shop
Old 11-06-2003, 08:32 AM
Mainjet2001's Avatar
Last Online: 07-28-2017 10:28 AM
Well I respectfully dis-agree to a point.
I'm a retired Sr Mfg Engineer and now run a small 25 man aerospace assembly shop.
I know a lot about Heli-Coils. Every airplane you ride in has a gazillion Heli-Coils.
Time serts are very good when you have a big loss of material in the hole, but I will use Heli-Coils in most repair conditions.
Breaking the tangs is a matter of technique and if you hit the tang wrong (they make a tool for this) it will distort the last thread.
My 2 cents (respectfully)
Old 11-06-2003, 08:38 AM
Yardpro393's Avatar
i use helicoils as well. i have used the time serts for oil drain bolt repair, and spark plug hole repair, where you need a solid piece
Old 11-06-2003, 10:21 AM
MotoMan's Avatar
Last Online: 10-31-2018 03:40 PM
Those are pretty cool, I never heard of those before.
Old 11-06-2003, 11:05 AM
motorox's Avatar
are these time-certs effective for cracks that have formed in the threads. mine is not only stripped, but under a magnify glass there is a hairline crack in the threads, which makes the drain plug leak.
I was told that if the crack gets worse i will have to buy a new case.
Old 11-06-2003, 11:58 AM
MATTXR250R's Avatar
Last Online: 08-27-2008 08:35 PM
the right seat bolt is stripped on my CR. I have had the seat off quite a few times since I have had the bike..I noticed that the bolt hole had a little sleeve(looked like that time sert thing)in the hole..well it must have fell out when I had the bolt out last or something and now the bolt won't screw in because the origninal threads are stripped:..so I had to use 2 wire ties and tie it down :
Similar Threads for: Stipped threads - Check this fix!
striped my threads mtalent 2-Stroke Dirt Bikes - Yamaha 5 11-27-2007 04:17 PM
where do you see threads you have posted? minus16969 General Discussion 4 04-10-2007 12:08 AM
