Old 11-14-2006, 07:57 PM
TheRooster's Avatar
Last Online: 04-07-2007 01:59 AM
Default Stainless Steel Work Bench
How much would it cost to do a work bench that is approximatly 3' x 10 - 12'?
I am thinking about putting a stainless steel topping on my work bench, however, I have no idea where I would even start, where I would get the supplies, or how I would attach it to the wood that is currently on there.
Any information about it would help a lot!
Thanks.
Old 11-14-2006, 07:58 PM
MotoMan's Avatar
Last Online: 10-31-2018 03:40 PM
Default Re: Stainless Steel Work Bench
I know how I would attach it, but I no idea where you would buy a sheet that big.
Old 11-14-2006, 08:06 PM
TheRooster's Avatar
Even if I have to attach like 2 or 3 sheets, that's fine.
Any idea on price? How to attach it?
Old 11-14-2006, 08:14 PM
MotoMan's Avatar
Drill holes in the perimeter of the ss, use a countersink bit and countersunk screws.
Old 11-14-2006, 08:43 PM
char393's Avatar
cha cha
We asked about this for the workbench, the guy at Home Depot directed us to their construction division. Maybe check a metal shop?
Old 11-14-2006, 09:18 PM
KKXR400R's Avatar
Try going to an A/C or sheet metal shop. They can also bend it for ya. You will probably spend a pretty penny but its worth a shot.
-Kevin-
Old 11-14-2006, 10:46 PM
crdemon's Avatar
Last Online: 04-12-2012 09:37 PM
If you can weld it would be pretty kool to make one
Old 11-15-2006, 05:59 AM
shany24's Avatar
Last Online: 11-21-2006 06:16 PM
Go to your local Steel supply factory and they can hook you up. They have rolls of Stainless steel that they can cut to length for you. They should charge by the linear foot.
Old 11-15-2006, 01:53 PM
dirtdemon4life's Avatar
Last Online: 05-29-2011 03:10 PM
I'll tell ya this much.. Stainless is NOT going to be cheap especially for that much... Sheets usually come in 4x8, and for a work bench top (with a plywood base) you will want 1/8" or more... Mild steel would be a bit cheaper, not sure if rusting would be an issue depending on where you put it and such. For that much your looking at AT LEAST $400 just for a sheet...
Old 11-15-2006, 03:00 PM
VET393's Avatar
Last Online: 09-17-2013 12:07 PM
5'x10'x16gage approx. $625 stainless steel plate
Sketch something , I will make a print for you.
Old 11-15-2006, 07:43 PM
Keetoman393's Avatar
Da Bunny
Last Online: 12-22-2016 04:50 PM
I work in the oil and gas industry as a supplier and I can tell you right now, you are looking at some serious money with that much stainless steel! Vet's figures are pretty much what you will be looking at... today. They change daily and we have seen a 10 dollar per pound increase in the last few months with no end in sight.
You may want to just try a high carbon steel surface and just keep it oiled or cleaned.
Old 11-15-2006, 08:03 PM
crdemon's Avatar
What kind of program do you use? Ive been thinking bout making a custom bumper.....
Old 11-15-2006, 09:26 PM
TheRooster's Avatar
I'll most likely be going with Galvanized, since that's A LOT cheaper, and works just as well.
What size should I go with? What would be a good thickness? 1/16 of an inch? That's a little thick, and would be around $150 to cover my work bench. 1/32, which is half of 1/16 for all you mathmatically challenged people out there, :, I could cover my work bench for about $60 - $70. Much cheaper. How thick do you think it should be?
Old 11-15-2006, 09:47 PM
psycho393's Avatar
Last Online: 09-14-2015 04:18 PM
The thicker you go the less dinged up and abused it'll get when you set stuff on it.
Old 11-15-2006, 09:51 PM
TheRooster's Avatar
Yes, I do know that...
However, I could replace the top two or three times with the 1/32 as apposed to paying for one 1 set of 1/16th top.
Old 11-15-2006, 10:30 PM
psycho393's Avatar
If a job is truly done right the first time you'll never have to do it over again and it will always maintain it's original quality when properly cared for.
Old 11-15-2006, 10:44 PM
TheRooster's Avatar
It's 1/32 of an inch thick... it will get beat up over time. I don't use the bench a WHOLE lot, but it does get used. Mostly just to keep oil bottles on when filling my bike(s), keeping clean and dirty filters... etc. So, that would last quiet a while, however, it is pretty thin, so it won't last forever.
Old 11-16-2006, 12:37 AM
b-bike393's Avatar
Last Online: 09-11-2016 08:08 AM
What you also need to think about is having the sheetmetal bent so as to provide a "Back Splash". With a back splash no spills will run down the back side.
Just my 2-cents.
Old 11-18-2006, 08:28 AM
check out a restaurant supply site
Old 11-18-2006, 10:55 AM
Da Bunny
Just my 2-cents.
Not only that but it keeps the important little parts from becoming runaways. Don't ask me how I know...
Similar Threads for: Stainless Steel Work Bench
I'll be sitting on the bench for a little while yzernie General Discussion 13 02-11-2006 12:33 PM
anyone use a stainless oil filter? hondageek 4-Stroke Dirt Bike Bike Forums 51 02-20-2004 01:04 AM
Stainless Filters VET393 General Discussion 20 01-18-2004 11:19 PM
