Old 06-08-2011, 01:53 PM
blueovalandy's Avatar
Last Online: 10-06-2017 11:54 AM
Being an air cooled engine, the valve guides are usually set up a little looser than most typical water cooled models. Because of this, the valve stem seals need to be in good condition. The xr400 uses high quality positive PC type seals that do an excellent job in controlling oil seepage past the guides. If the engine is smoking a lot, my guess would be the problem is in the cylinder. When you get the top end apart, take the jug and piston to a machinist who can accurately measure the cylinder and piston for wear. If it doesn’t fall within the recommended clearances, have it bored to the smallest possible overbore size. Then have the machine shop preform a vacuum test on the head and if it fails, have them grind the valves and cut the seats. Then put it together with new gaskets (including new valve stem seals), new timing set (I think some CRF chains will interchange and are cheaper and stronger), and a new cam chain tensioner (I prefer a manually adjusted tensioner). After all of that you would have spent around 400ish dollars but your bike would be ready to run for a long, long time.
Good Luck
Andy
Old 06-08-2011, 02:04 PM
supercr125's Avatar
Last Online: 03-02-2016 12:12 AM
id like to do that, but i dont have 400$ to spend on it... so im just going to re-ring it and do new valve guide seals for right now
Old 06-08-2011, 02:14 PM
dodging_roost's Avatar
Last Online: 05-30-2018 07:46 PM
At least make sure you just run a hone through the bore.... otherwise the rings will never seat properly.
Thanks
Scott
Old 06-08-2011, 02:18 PM
Florida 393's Avatar
Semper Fidelis
Usflag
Before you go into the top end please order the factory shop manual. You can get one from a dealer or order it from the Honda website. This is a really thorough manual that will get you through most anything you attempt.
Best of luck with diagnosing the problem and read Mainjet's PM's carefully. He knows his stuff on these bikes.
Bill
Old 06-08-2011, 03:20 PM
supercr125's Avatar
yea if i do the rings i am deffinatly going to hone it!! is the cylinder plated? nikasil plated? and i do read his pms VERY carefully, also i will be buying a workshop manual soon to
Old 06-08-2011, 03:26 PM
Don't know on the newer ones but the older ones were all steel sleeves. Whoever you have run the hone through it should be able to tell.
Thanks
Scott
Old 06-08-2011, 03:27 PM
supercr125's Avatar
alright cool
Similar Threads for: smoky xr400
Smoky!! dangerSteve 2-Stroke Dirt Bikes - Honda 3 02-09-2009 06:31 PM
XR 650 or XR400 kodiak 4-Stroke Dirt Bikes - Honda 7 08-23-2004 08:00 PM
XR400 CDI nate650 4-Stroke Dirt Bikes - Honda 11 12-11-2003 11:06 PM
Anybody Have an XR400? OLDMXRACER 393 4-Stroke Dirt Bikes - Honda 16 11-30-2003 07:06 PM
Smoky oily pipe with mass oil consumpsion! VirginRider 2-Stroke Dirt Bikes - Kawasaki 14 09-04-2003 08:10 PM
