Old 02-06-2019, 08:27 AM
gusco's Avatar
Last Online: 05-27-2020 05:06 PM
Default Scariest Moment Ever
Had the biggest scare to date since I began working on bikes (about 14 years):
I had a guy coming to look at a '00 yz125, but I needed to replace the tank because the original was cracked. So, I rushed home during lunch and got it switched. After work, I checked everything over and started it up. It had fired up before and run decently up and down the block (I usually run them once before buying parts to check the clutch/trans without opening it up. Well... the idle was hanging so I started checking over the air screw and idle settings. It would hand and then load up and die. After a few tries, I started it, and it completely ran away on me. Kill switch didn't kill it, disconnected plug cap and fuel, but it still didn't die. I started to panic and then realized if it ran out of oxygen it should shut off. So, I plugged the exhaust with my palm and sure enough it died. Scared the CRAP out of me. For a few seconds I was just expecting it to grenade as I scrambled to try to kill it.
SO: IF you ever have a bike run away, just know that plugging up the exhaust will kill it pretty quick.
Also: The guy wound up taking it because he was going to do a full rebuild and fully restore the bike anyway and was only interested in it being complete.
Old 02-06-2019, 08:29 AM
Last Online: Today 11:18 AM
Sheesh, that could have ended up much worse! Glad it all worked out in the end.
Old 02-06-2019, 09:13 AM
gusco's Avatar
Definitely! Especially considering that I disconnected the spark plug cap and it was arcing everywhere... and I had spilled some gas at lunch time transferring the gas over to the new tank. Thank God it was just the scare... and ear damage, hahaha!
Old 02-07-2019, 06:14 AM
Last Online: Today 09:06 AM
Just drop it in gear while holding the brakes. This has happened to me a several times over the years while running the carb dry for storage. I am always prepared for it now.
I have heard that you can hold the throttle wide open and it will kill it, but I have not tried it.
Old 02-07-2019, 07:56 AM
gusco's Avatar
That's a good idea! I totally panicked and resorted to yelling like Chewbacca for about a minute trying to think of things to do to kill it while trying not to get shocked by the arcing cap (worst idea ever, by the way...)
Old 02-07-2019, 01:59 PM
bjunior's Avatar
novice
Last Online: Today 01:42 AM
Thanks good to know. Also good to know the out wasn't bad for u.
Old 05-31-2019, 09:47 PM
bweighmaster89's Avatar
Last Online: 12-04-2019 10:32 PM
Do you happen to have the video ? Happened to me in Feb. Inside steel offshore container shop , while on the lift , short legged me , can't reach clutch and brake at the same time , kill switch , uh No , fuel valve , uh No . . Plug wire uh No . YZ 250 Just SCREAMIN .. Panic , Look around , For What ?? OMG . IT'S GONNA BLOW ..... THEN BAAAAAA!HHHHHH.... THEN , Laughter .. How Funny . Would have liked to see , Your face , Or mine .... S.... tuff happens
---------- Post added at 08:47 PM ---------- Previous post was at 08:42 PM ----------
If tank is cracked , sometimes i can plastic weld ... will give it a shot , nothing to lose ...
Old 06-01-2019, 07:13 PM
gusco's Avatar
I wasn't taking video, but I'm sure my face was hilarious to look at. I already sold the bike a while back and replaced the tank.
Similar Threads for: Scariest Moment Ever
Duh Moment dandroz240 2-Stroke Dirt Bikes - Honda 11 04-22-2011 08:19 PM
Scariest Experience Of My Life Rockey General Discussion 15 07-07-2005 05:18 PM
Embarrassing moment AndrewPA General Discussion 11 11-18-2004 09:54 PM
Top GMB III Moment Dirtbikindad393 General Discussion 11 10-17-2004 08:44 PM
O/T Scariest thing ever just happened Live2ride General Discussion 13 06-27-2004 07:28 PM
