Old 07-21-2004, 10:46 PM
Crazy's Avatar
Last Online: 01-19-2014 09:57 PM
Default Routine checkup
How often do you guys recommend tearing out the axles and greasing and cleaning them? How about the suspension linkages?
Are there any other things I should be checking on a regular basis?
Right now all I do is regrease the axles about every month or so. I also take the chain off about every 3 rides and soak it in gas, then scrub the chain using a brass brush, and follow up with a good lubin.
Old 07-22-2004, 02:09 AM
Age is a state of Mind
Last Online: 12-24-2018 11:29 PM
Default Re: Routine checkup
As far as the axle's When ever I have the rear tire off, I always grease the axle, and the bearings in it.
As far as the other stuff (swing arm, linkage, shock mount points, and head bearings, and anything else I might be forgetting) I'd make sure and do them at least yearly. If you ride in muddy/rainy conditions or ride a lot, I'd do it semi annually.
I'd also change the fuids in both the shock and forks at least every 6 months if you ride a fair amount. Annually if you don't. You would be surpised how much difference it makes to have fresh fluid in their.
Also just a tip for you on the chain since you seem to take better care of your chain then most people I know. Almost all suspension fluid on the market is junk, and is more of a dirt magnet then a lube. I'd look into buying some chain lube from http://www.best-motorcycle-chain-lube.com/ I have both MX1000, and Ultra Lube, and I prefer the ultra lube. But both are awesome. Application is a little more tedious, but well worth it.
No mess on the swingarm and hubs either. This stuff is just awesome.
Old 07-22-2004, 02:23 AM
Aus_Rider_22's Avatar
Last Online: 02-12-2019 05:47 PM
Yeah what Johnathon said. Everytime I have me back wheel off it gets cleaned and fresh grease applied.
Similar Threads for: Routine checkup
What's your tie down routine? chabat General Discussion 37 06-01-2005 11:17 AM
10 week checkup on ACL Reconstruct nappers Fitness, Training, & Recovery 12 09-02-2004 08:31 PM
Are there any online resources to guide thru routine maintenance? havnfun 2-Stroke Dirt Bikes - Honda 4 04-07-2004 08:07 PM
