View Poll Results: Best goggles
Spy 1 33.33%
Scott 1 33.33%
Okley 1 33.33%
Smith 0 0%
Voters: 3. You may not vote on this poll
Old 05-22-2010, 05:20 PM
Last Online: 05-23-2010 12:38 PM
Default Rm 250 chain touching rear tire
I have a 03 Rm 250 my chain touches the tire to where the side of the chain is polished And rear tire sets to the left In the swingarm I bought this bike used so could the spacers be wrong or somthing else has anyone else had this problem
Old 05-23-2010, 02:41 AM
Age is a state of Mind
Last Online: 04-01-2020 03:52 PM
I've only ever seen that when the chain has been run too loose.
But yes, the spacers could be on the wrong side I suppose -- or the rear wheel could no longer be true as it's supposed to be.
Old 05-23-2010, 05:37 AM
BBA BBA is offline
Last Online: 02-28-2015 05:30 AM
Check for proper spacing first on your wheel but it sounds to me like your rear wheel is dished wrong and is too far to the left. If you are good at truing wheels all you need to do is start with a quarter turn loose on the left side spokes and tighten a quarter turn tight on your right spokes. Just make sure you have enough threads on your right spokes to do this and they will not go in too deep and stick up inside of your rim. This will take care of your problem with the chain hitting in most cases.
If your not comfortable in messing with your wheel/spokes just take it into your local shop and tell them to dish the wheel a little to the right. Hope this helps.
Old 05-23-2010, 12:26 PM
If your wheel is "dished wrong" send me a picture. I need one. I am guessing that you already checked alignment with a tape, and that the swingarm bearings and wheel bearings are in good shape? No play etc? When the bike is on the stand, and everything is lined up (ie axle parallel with the swingarm pivot bolt) does it touch when turned then?
Old 05-23-2010, 12:37 PM
Default -
Thanks for the help I have a buddy who works at a local shop comming over to check out the wheel thanks again
Old 05-23-2010, 04:01 PM
BBA BBA is offline
Umm maybe there is another terminology for "dished wrong" but thats just what everyone calls a wheel pulled by the spokes too far to one side that I know??? Sorry, Im just a backyard wrencher that has seen this before lol!
Old 05-26-2010, 09:02 PM
Last Online: 05-26-2010 09:35 PM
They are all good. Buy what ever ones are on sale when you go looking
Old 05-27-2010, 01:02 AM
BBA, I used to see it a lot too, but since then the manufacturers have made a much better wheel with a much better rim and what amounts to being straight spokes. On those I just don't see it anymore. I am not sure I could get one more than a 1/4" out if I tried. Heck some of the ones I laced up in the 60s' wobbled bad enough to hit the chain.
we put a Riken 4.00 on a Yamaha 80 once. It would hit the chain of you had it properly aligned. Wasn't easy to get on that rim, but to a couple of 16 year olds, it seemed worth it.
Old 05-27-2010, 05:04 AM
BBA BBA is offline
Yeah your right on the mfgs using a lot better wheels/spokes these days like DID & Excel. I guess I was thinking more of if someone had laced up a new rear rim on his bike since he said he just picked it up used. I just had a front wheel on my Honda that I had to fix that was off to the right side. I used ProWheels & White bros spokes and oddly enough it was pretty far off the first lace up
If everything else is lined up in the swingarm like its supposed to be, the chain is not too lose and the proper shims are in place on the hubs thats the only other thing I think it could be.
A 4.00 on a little 80???? Now that must have looked like a dragster lol.
Similar Threads for: Rm 250 chain touching rear tire
'87 YZ 125 Rear tire customblue 2-Stroke Dirt Bikes - Yamaha 1 02-07-2010 09:04 PM
Chain/front tire questions- 06 450 cowboyona426 4-Stroke Dirt Bikes - Yamaha 16 06-04-2006 02:58 PM
rear tire? p8nt General Discussion 3 05-15-2004 12:22 PM
Which rear tire? MATTXR250R General Discussion 24 02-23-2004 06:28 PM
What Rear Tire To Run Dirtbikindad393 General Discussion 14 12-14-2003 07:44 AM
