Removing decals?This is a discussion on Removing decals? within the General Discussion forum, part of the Dirt Bike - ATV - Suspension Forums category; Any tips on removing old torn/shredded decals from aluminium (swing arm). I’m just concerned about the clear coat wile using ... |
| Any tips on removing old torn/shredded decals from aluminium (swing arm). I’m just concerned about the clear coat wile using something to aggressive. Also removing them off plastic? Thanks, |
| Heat the decal up with a hairdryer and they will peel right off. Remove any residue glue with paint thinner. |
| I honestly don't know the best method, but I do know that if you take a heat gun or a hair dryer you can heat them up and then pull them off. Then use some Brake Cleaner to clean off the residue. I've not done it, but when I put my stickers on, I used a blow dryer to heat them enough to lift them back up to remove bubbles. It worked like a charm, but I think someone will probably post a better way. Good Luck |
| 3m makes adhesive remover that works well |
| Once I get the sticker off,as you know it leaves that sticky glue behind as Rick mentioned. To get that off I use this stuff called "GOO GONE".it takes it right off,it also smells kinda like oranges. Comes in a little plastic bottle. Put it on and then take your finger nail and it will just come off as you slide your nail over it. |
| Thanks guys! |
| no problem...anytime |
| I'm thinking of replacing the swingarm stickers on my CR, so this thread is alot of help...Thanks Guys! |
| Yeah I use the Goo B gone stuff. I make a trip to Lowes and buy huge bottles of Simple Green (the best stuff ever made) and Goo B Gone. If the stuff is really thick, it will take a couple squirts but have no fear because it gets it every time. |
| ANYBODY WANT SOME ATM DECALS??? ALL LOOK!!!!! | TRXman86 | General Discussion | 12 | 11-23-2004 10:12 PM |
| atm decals | crdemon | General Discussion | 36 | 11-19-2004 06:38 AM |
| Over 1000 Decals | ktm125250 | MC & ATV Parts & Accessories | 3 | 08-29-2004 06:12 AM |
| gmb decals | squizzleboy | GMB Remembering Those Who Rode | 5 | 08-23-2004 11:19 PM |
| anyone want some decals? | Riley_400 | General Discussion | 4 | 04-28-2004 12:50 AM |
