Old 12-02-2018, 09:41 AM
Last Online: 01-02-2019 11:03 PM
Smile Rear tire position, chain tightness, studded tires
Thanks for taking the time to read my question.
I am putting on ice tires (IceKing with Marcel Fournier studds) and i need to move my rear tire back so that the studds don't hit the "armpit" of the swing arm. If i move it back as far as it goes i have a space of one link missing. This is fine as i thought i could get another master link and use the cutoff from my chain that i kept. The problem is the chain is too slack and i cant go further back . i could move it forward but then i would only have half a link space which of course doesn't work. I can move it forward more so i have no space and i can join the chain with the master link but there isn't much slack and the studds look really close to the "armpit".
I'm not overly mechanical and can't figure out how to solve this.
BTW, i determined spacing by putting my chain on my bike and having the two ends of the chain on the rear sprocket to see how many "U's" are left.
I have a 2007 YZ250 if that is helpful.
Thanks!
Old 12-29-2018, 10:30 PM
I put on a 13 tooth front sprocket, one less than stock. This is the same as half a chain link.
Old 12-30-2018, 12:09 AM
bjunior's Avatar
novice
Last Online: Today 02:34 AM
I would determine what leanht i need ether buy that sze or have one made. When looking at what leanth of chain u have to consider front and rear sporket size. determine how far back it needs to move to be safe to clear the added leanth of tf the studs.
Old 12-30-2018, 12:38 AM
Thank you for your reply here too bjunior
The different front sprocket solved my issue and I didn't have to buy a new chain.
Mbrad
Old 12-30-2018, 01:14 AM
bjunior's Avatar
novice
Some claim adding more than 1 masterlink makes it weak I have not tried it.
Similar Threads for: Rear tire position, chain tightness, studded tires
Riding without studded tires? dirtrider25 General Discussion 4 01-28-2013 07:59 AM
chain is ripping chunks out of my tire mdryan10 2-Stroke Dirt Bikes - Suzuki 2 07-12-2011 10:26 PM
Rm 250 chain touching rear tire Mxgoon823 General Discussion 8 05-27-2010 06:04 AM
Chain/front tire questions- 06 450 cowboyona426 4-Stroke Dirt Bikes - Yamaha 16 06-04-2006 03:58 PM
how can you find out the weight of mx tires, or which rear tire is the lightest? bigguns30 General Discussion 3 11-22-2004 03:14 PM
