![]() Check a parts schematic on any oem part seller's website. |
![]() The bottom nut of the three should be tightened against the bottom u shaped arm. Without this in place and tight , the master cylinder plunger will turn and thus come loose. Also one nut should be under the U shaped arm as well. http://www.bikebandit.com/oem-parts/...5869#sch110417 Paw Paw |
![]() The two nuts don't look right... Must have posted as paw posted ![]() |
![]() Yup. Just checked my CR. It only has one nut and it is up against the clevis, not up by the cylinder. |
![]() Thanks Paw will try it soon. I thought it went inside the u shaped arm but when I tried to get the nut back on I had know idea how I could tighten it so I just assumed both go together. |
![]() Put one inside the clevis (u shaped arm) and twist the clevis to get the brake level at the height you want, then tighten the other nut against the top of the clevis to lock it in place. |
Bookmarks |
Thread Tools | |
rear brake problem | hondamxrider63 | 2-Stroke Dirt Bike Forums | 3 | 07-12-2008 08:05 PM |
01 KTM 125sx rear brake pad help! | nw0rbrolyat | 2-Stroke Dirt Bikes - KTM | 1 | 07-01-2008 03:20 PM |
tapping rear brake in the air | kawamama3 | 4-Stroke Dirt Bike Bike Forums | 7 | 05-09-2008 01:52 PM |
Rear brake pedal for 450 | Redscooter | 4-Stroke Dirt Bikes - Honda | 5 | 04-29-2005 12:09 PM |
Rear brake problems | Redman450 | 4-Stroke Dirt Bike Bike Forums | 5 | 02-16-2005 07:05 PM |
