Old 04-17-2014, 05:00 PM
Last Online: 05-29-2014 06:46 PM
Default Re-using copper head gasket?
So i just replaced the head gasket on my cr125 when i replaced the whole top end. It ended up running great but it leaks black liquid from the bolts so i bought a new head gasket. The new one wasn't Aiseco like the one that leaked was but it didn't fit because my bike is bored out and i cant buy a new gasket anywhere unless i buy an entire kit which I don't need.
Can i re-use the gasket? Why is it leaking? I took it off because i thought it was on wrong but it wasn't, so I' wondering if maybe it wasn't broken in and will go away?
Thanks,
Isaac
Old 04-17-2014, 11:47 PM
Tdub's Avatar
Last Online: 01-22-2016 10:26 PM
Copper head gaskets can be reused if annealed...heat it up till she turns colors and quench it in water or oil or just air cooled...burnish the color off with a scotch brite pad, coat with Coppercote and install...JMO
Old 04-18-2014, 12:33 AM
Last Online: 12-07-2017 10:13 AM
If it is symmetrical, turn it over too.
Old 04-18-2014, 06:36 PM
Well we ended up ordering a new one anyway, and now my question is why? why did it leak through the bolts? Does it just need to heat up? Could i have installed it wrong? The raised bumps go up and the tab toward the back. I don't want the new one to leak.
Old 04-20-2014, 11:43 AM
Bump..I would really like to know if there is something i did wrong or any reason why it leaked? I don't want to waste another $30 for the head gasket and have it leak again.
Thanks
Similar Threads for: Re-using copper head gasket?
head gasket 4chevys4me 2-Stroke Dirt Bikes - Honda 3 07-19-2012 02:30 PM
New head gasket? roostonyou 2-Stroke Dirt Bikes - Honda 8 06-28-2012 12:25 AM
cr 250 head gasket Derekrm250 General Discussion 0 06-26-2011 04:34 PM
copper head gasket not sealing. dtdynamics 2-Stroke Dirt Bike Forums 3 03-07-2009 07:07 AM
Head Gasket Bucmaster 2-Stroke Dirt Bikes - Honda 9 05-25-2005 05:43 AM
