Old 01-10-2006, 07:20 PM
Last Online: 06-26-2008 01:52 AM
Default Quick question
Hey just need a quick answer. I have bought a rear fender decal from ebay and recieved it today, it has no instruction so is it just something you slap on like a normal sticker or do i have to use a special glue to help the sticker stay on? And do i have to clean the surface with solvent's or anything?
Thanks.
Old 01-10-2006, 08:01 PM
Aus_Rider_22's Avatar
Last Online: 05-12-2019 12:58 AM
Default Re: Quick question
I recommend mixing up some dishwashing detergent or Windex type product with water and putting that on clean plastic surface.
Then you can move and manipulate the sticker to excatly how you want it. Then use a heat gun or hair dryer to melt the glue on sticker.
Old 01-10-2006, 08:41 PM
Thanks for the response did you mean use the heat to help the sticker stick or add glue to the sticker and use heat to dry the glue?
Old 01-10-2006, 08:45 PM
CowAsocky's Avatar
Last Online: 02-14-2009 03:49 PM
Heres a link to help you in your sticky situation :
http://www.transworldmotocross.com/m...144324,00.html
Old 01-10-2006, 08:56 PM
Last Online: 06-13-2013 04:37 AM
best way to apply a decal: get a small bucket of warm water with a small amount of dish soap mixed in. take a rag or sponge material and clean the area real good. leave it wet but not to wet the decal will drip off with the water. adjust to where you need it. hold it in place with one hand, then with the other, wipe with the sponge or rag (wet but not dripping) the opposite way of your hand. (holding with left, go from left to right) be sure and go slow incase it moves. then you can move it back. once it is in place and holding, wipe away ALL remaing water/liquid. be sure and get all air pockets out. best way is to use a plastic squegee(SP) and work them out the shortest way possible. bubble on top, work out to top. in middle, work out the shortest way. with a heat source (heat gun or hair dryer) begin to warm the decal to increase the stickyness (DO NOT ADD GLUE!!!!) dont get to close to melt it, but not to far away. be sure and rub it on with your hand or a dry towel as you heat...use minimal pressure. once this is done, if there is still air pockets, take a razor blade and put a very tiny hole in the center of pocket, rub with your finger to remove while applying heat. that should be about it i think. this is the way we do it on our race cars hope it helps some.
also look where cowasocky said to be safe LMAO
Old 01-10-2006, 09:14 PM
Just lay and place the sticker where you want it lined up, then simply aim the heat at the sticker and the heat will dry it and melt glue. It will take a bit, but stay patient and it will stick nicely
Old 01-10-2006, 09:31 PM
Thank's a heap guy's i might put it on tonight.
Old 01-10-2006, 09:46 PM
schwen_108's Avatar
Last Online: 03-06-2019 03:09 PM
The really best way to put on backgrounds are you stick them on. if there not aligned peel off and re do..here's a link from a pro.
Fusion Graphix Install Tips
Originally Posted by Tyson Blood @ Fusion Graphix
Do not use water or liquid to install, it will soak into adhesive causing problems.
Old 01-10-2006, 09:47 PM
Sweet!
Let us know how she goes
Old 01-10-2006, 10:03 PM
If you are going to follow that route then you have no room for error. Be careful to place your graphics and don't stick them until you are sure it's how it's supposed to go.
Similar Threads for: Quick question
Quick Question Shoei_391 2-Stroke Dirt Bike Forums 1 05-06-2007 09:08 PM
OT: Quick Question Silver_Fox General Discussion 8 03-15-2005 06:48 PM
quick question CR Chick 2-Stroke Dirt Bike Forums 2 02-23-2005 06:04 PM
Quick question about AMA ThumperCRF250 General Discussion 19 02-11-2005 04:38 PM
quick question Z-Man 393 General Discussion 3 03-02-2004 09:58 PM
