Old 04-29-2012, 12:49 AM
Last Online: 09-06-2013 06:57 AM
Default please help please
i have a little 125 thumpstar i can ride it for maybe 1 minute untill it will die and wont start again for another 5 minutes? i have changed sparked plugs cleaned the carby. what else can i do or do you know what is wrong with it please help me asap cheers
Old 04-29-2012, 01:26 AM
I would make sure that I can empty a whole tank of fuel with the cap on out the hose coming from the tank without the fuel stopping it's flow for a gulp of air. it should run pretty fast as well. As you can see I am thinking you have a fuel delivery problem. The next step if you are getting good fuel flow is test the stator and or coil.
Old 04-29-2012, 07:29 AM
Default Maybe
Ok, the next time it quites on it's own, just remove the fuel tank cap, put it back on and see if it will start. The tank cap vent could be clogged.
Also clean all of the carb vent tubes.
As stated above the coil or stator could be breaking bown from heat and the you loose spark.
Old 04-29-2012, 07:36 AM
Last Online: 04-29-2012 07:45 AM
If the gas flow stream from your tank is not steady, and the breather is not clogged,You may also have a clog in your petcock (gas on/off lever). If you can, check your tank for debris that may have fallen from a dirty gas can. Just one of those things that happened to me once.
Old 04-30-2012, 07:01 AM
ok i have cleaned the carby out good checked all fuel lines, and everything is unblocked and it all flows fine. started it and rode it for roughly 2 minutes they there was no idel and it died and did not want to start again. what else should i try really want to get it going good
Old 04-30-2012, 07:07 AM
arnego2's Avatar
Have a look at the plug, dry or wet? And when dying did the engine surge as if being starved of fuel?
