Old 05-01-2010, 06:20 PM
Last Online: 08-21-2012 01:37 PM
Question Please Help With My Electrical Issue
I have finally diagnosed the backfiring and missing problem on my 1987 YZ125 to the electrical system. The bike idles fine, but at medium revs it starts backfiring and missing. Where do I start first? Should I pull the flywheel and check the timing plate? What component failure can cause this?
Any help is appreciated
Old 05-01-2010, 11:38 PM
Last Online: 05-10-2010 06:54 PM
Put a new plug in NGK and gap per manual. If that doesn't do it Pull cover and make sure flywheel is tight. Then line up marks on plate with magneto.But to me it sounds like jetting
Old 05-02-2010, 04:24 PM
I installed a new NGK plug, with no luck. I cleaned the carb, and I have not changed the jetting. The electrical system is fine. I figured out last night that the powervalve arm does not move. So I suppose that is the problem? What can cause it to stop working?
Similar Threads for: Please Help With My Electrical Issue
KX 500 electrical? josh97546 2-Stroke Dirt Bikes - Kawasaki 3 04-19-2010 09:16 PM
HUSKY ATV ELECTRICAL unclebro ATV/UTV Forums 1 10-16-2008 10:09 PM
need some electrical for my 83 cr80 slink242 Classified Ads 2 01-10-2005 04:09 PM
Any electrical geniuses out there?? 2fun General Discussion 0 11-08-2004 05:09 PM
electrical issue klp 2-Stroke Dirt Bikes - Yamaha 4 09-06-2004 01:34 PM
