Old 04-20-2010, 09:02 AM
VET393's Avatar
Last Online: 09-17-2013 11:07 AM
Default OT: Adding Memory to PC
When you add memory to a PC, is there any adjustments to BIO's that need to be made, so PC recognizes new memory?
Old 04-20-2010, 09:56 AM
Dano426's Avatar
Last Online: 08-21-2012 06:01 AM
Yes, but most of the computers will recognize the memory change and notify you at start up. You can also enter the bios and save the new settings, not changes need to be made, just enter bios and save and exit.
It should tell what keys to hit before the Windows splash screen appears.
Old 04-20-2010, 10:09 AM
VET393's Avatar
I installed memory and hard drive runs excessevly, I was told I need to adjust bio's for new memory. I was told it was searching between the 2 memory cards.
Old 04-20-2010, 10:42 AM
Age is a state of Mind
Last Online: 10-10-2018 11:27 PM
Never heard anything like that.
Does it see the new memory?
Typically you don't need to do anything unless it says you need to (on initial boot). If you installed more memory and you are getting a ton of hard drive activity, you more than likely did not get the memory installed, it's broken, or it's the wrong memory and your computer can't see it/use it.
Old 04-20-2010, 11:25 AM
VET393's Avatar
It says the memory is there, I am just curious. Someone told me in a conversation about resetting the bio's and I'd not heard of doing that.
Old 04-20-2010, 02:03 PM
Dano426's Avatar
I should rephrase my statement. I do not change the memory size in the bios. It reads the new memory size and you just save the new settings.
Sounds like you have some bad ram.
Memtest86 is a good way to test that
Memtest86 - Download Page
Old 04-21-2010, 12:53 AM
lucky's Avatar
Last Online: 01-03-2012 06:38 PM
by memory do you mean ram or hard drive space
Old 04-22-2010, 03:38 PM
Duran676's Avatar
Last Online: 08-02-2012 04:12 PM
agreed it is important that you specify which one.
If you added more RAM did you use the same size and brand?
Or are you trying to set up your hard drives in some kind of RAID array??
Similar Threads for: OT: Adding Memory to PC
PICTURES WITH A MEMORY Mainjet2001 General Discussion 14 10-21-2007 04:03 PM
memory lane pjg351 Vintage Riding 2 08-28-2007 05:48 AM
in loving memory pikle311 General Discussion 22 11-26-2004 04:27 PM
Data recovery - memory stick... monoshock General Discussion 2 03-14-2004 04:38 PM
2004 Houston Supercross - An Honor for Garretts Memory Motodad393 GMB Background and History 32 03-08-2004 09:38 AM
