Old 11-28-2004, 06:38 PM
dixienw123's Avatar
Banned
Last Online: 06-22-2006 10:20 PM
Default old.....TS185 jetting and other problems?
hey guys, i recently got a 1973 or 74 ts185 and have a few minor problems maybe you could help me with...
First, going up the road i can run the bike w/ choke or no choke and will run fine...It will idle fine(in a way) with choke on but will idle higher and higher un till i kill it ........with the choke off it wont idle at all.
Now, puttsin around,(w/ choke)off idle in 1st gear it will just not do anything(like no gas at all) I have to give it almost 1/2 throttle for it to rev out....with choke off it will run(OK) maybe? but then wont idle......The plug looks really rich even if i leave the choke off............
It is the mukuni round slide carb.
I cleaned and recleaned the carb. Could it be im not mixing the oil right or bad gas?????
Im also thinking of selling it so i can get some $$$$$.
Sory for the long post
Thanks ALOT
Old 11-28-2004, 06:56 PM
crdemon's Avatar
Last Online: 04-12-2012 08:37 PM
Default Re: old.....TS185 jetting and other problems?
what are you running for a fuel oil ratio?
mabey cdi or coil? do you have a strong spark?
Old 11-28-2004, 07:10 PM
dixienw123's Avatar
Banned
i am running 32ish:1 but its boat outboard oil, i also ran like ACE weed wacker oil....Never got around to getting good oil
The spark is not the best but is still blue....The other day i got it to run backwards.....: didnt run good but ran weird.....anyways it has the setup w/ 2 plugs on the head and the one runs better than the other even when there both brand new....
Thanks
Old 11-29-2004, 05:40 PM
dixienw123's Avatar
Banned
What does anyone think i should do?
Old 11-30-2004, 06:35 PM
HiG4s's Avatar
Last Online: 03-09-2013 07:29 AM
carbs get gummed up,, clean it throughly,,, and maybe even replace the jets and air and idle screws, , they are suseptable to corrosion over the years and may not actually be metering the air and fuel as was originally intended.
Old 12-01-2004, 11:11 AM
those bikes have an oil injection too. Why are you adding premix? Theres your problem
Similar Threads for: old.....TS185 jetting and other problems?
YFZ Jetting Problems nick658 ATV/UTV - Yamaha 3 11-13-2008 09:19 PM
New 1977 Suzuki TS185 Problems jczlsr 2-Stroke Dirt Bikes - Suzuki 5 08-14-2008 04:28 PM
Jetting(?) Problems Spitfire 2-Stroke Dirt Bike Forums 36 07-01-2004 09:03 PM
jetting problems dixienw123 4-Stroke Dirt Bike Bike Forums 19 06-16-2004 08:59 PM
jetting problems CRF450_RIDERED 4-Stroke Dirt Bikes - Honda 3 01-28-2004 01:01 PM
