Old 08-01-2012, 07:57 PM
whitey nocar's Avatar
Last Online: 04-12-2013 04:43 AM
Default Oil drain plug drips. What's the solution?
Just bought my 16 year old a 2000 cr 125 r. pretty clean bike, but dripping oil, I assume gear oil from the head of the drain plug. His old ttr 125 drips engine oil from the drain plug. Should these have a copper crush washer? I thought the yamaha wasn't suposed to use one...but what do I know? Any ideas on what will stop it?
Thanks
Old 08-01-2012, 08:04 PM
Tuck's Avatar
Last Online: 12-15-2014 04:11 PM
The CR should have a washer. If the washer doesn't stop the drip, wrap some teflon tape around the bolt.
2000 Honda CR125 OEM Crankcase Parts | MotoSport
Old 08-01-2012, 08:06 PM
Crogg's Avatar
Last Online: 03-14-2019 08:10 PM
Thanks
Yes it needs a copper or alum crush washer! The leak will stop as long as the threads aren't stripped!
Old 08-02-2012, 09:07 AM
yzernie's Avatar
Retired now a House Biatch
Last Online: 01-06-2019 08:42 PM
Oil is over-rated!!
Old 08-02-2012, 09:17 AM
Last Online: Today 05:56 AM
Default OK
Ok, if you don't have that washer and it's too hard to get from the manufactor, then go to Autozone or another auto parts store and pick up a drain washer kit. It will have several styles and types and sizes that can be used for your bike and it will be cheaper than the original, which no one stocks.
Old 08-02-2012, 09:31 AM
char393's Avatar
cha cha
Makes me happy for my local dealership, they stock things like that.
Like the drain washer kit idea though, might be a good thing to have on hand for the vintage and post vintage bikes.
Old 08-13-2012, 10:33 AM
wFo250's Avatar
will fall over
Last Online: 06-16-2019 09:18 AM
I wouldn't use Teflon tape as it can shred easily and get in the case when you go to change your oil. Get a washer. If I were to use tape it would have to be the petrol resistant type as it is thicker, and even then would twist into rope and only wrap several times at the base of the head not the threads. My .O2
Old 08-15-2012, 09:33 AM
Last Online: 10-17-2012 10:15 AM
I bought a 99' CR250 several years ago that had a stripped drain plug and dripped... The threads worked fine till you went to tighten it, then it would just keep rotating.
I drilled out the bolt hole a size larger, and installed a tapered pipe plug so it wouldn't protrude from the case and get hit again (the guy told me he cased on a rock and screwed up the drain bolt that way)... anyways, it was easy to drill and tap the new hole, and it worked like a charm!
Just be sure you flush out the gearbox if you do any drilling to make sure no shavings remain in there..
Similar Threads for: Oil drain plug drips. What's the solution?
New oil drain plug json 2-Stroke Dirt Bikes - Honda 0 04-06-2009 12:01 PM
Oil drain plug john082603 General Discussion 7 12-17-2008 01:59 PM
Drain plug Keetoman393 Classified Ads 0 03-10-2006 06:15 PM
DAMN drain plug Thesargent44 2-Stroke Dirt Bike Forums 20 09-09-2005 02:23 PM
drain plug leak motorox General Discussion 13 10-26-2003 11:00 AM
