Old 09-14-2005, 08:07 AM
maf1188's Avatar
Last Online: 01-14-2011 06:52 PM
Default Need help with my bike!!!!!
The last couple times I have went riding when I come into a corner hard and have to break hard sometimes my bike stalls and I have to bump start it so do any of you know what the problem could be? Like does it need to be jetted different? I have no idea so any help will be greatly appreciated.
Old 09-14-2005, 08:26 AM
Last Online: 07-17-2006 10:38 AM
Default Re: Need help with my bike!!!!!
pull in the clutch a little bit.
Sounds like the bike is fine, you may need to adjust your riding style
Old 09-14-2005, 08:47 AM
maf1188's Avatar
I do pull in the clutch! It feels like the RPMs are dropping to fast and the bike just dies. It is hard to explain so i'm trying to do the best I can. I'm not a pro but my riding style is fine it isn't that.
Old 09-14-2005, 09:08 AM
Satch0922's Avatar
sounds like it may be running a little rich. That would cause it not to idle and die as you decel. Also that would expain why it is hard to start once it dies.
If it just started, I would suggest first that you set the air screw and see how it runs. Then go from there.
FROM THE 2-STROKE KNOWLEDGE BASE FORUM
Motor won’t idle and idle set screw is ineffective. Try leaning out the airscrew by turning it counter clockwise a quarter turn at a time. If the airscrew has no effect, install a leaner pilot jet and return the airscrew to 1 turn out. Proper airscrew settings are usually between 1 and 2 1/2 turns out. The correct pilot for your bike is one that allows instant off-idle throttle response, and allows the airscrew to be effective between 1 and 2.5 turns out. If the problem still exists, check and clean the choke circuit and carb vent lines.
If you turn your airscrew 3 turns out you would need a smaller pilot.
Similar Threads for: Need help with my bike!!!!!
Would a 250 2-stroke bike be good for me, or its 2 much bike ? Gore 2-Stroke Dirt Bike Forums 34 05-01-2010 08:43 PM
Bike for 9 year old son (first bike) Ncognito What Dirt Bike or ATV 32 07-12-2007 12:14 AM
Push bike or workout bike? Deano249f Fitness, Training, & Recovery 32 07-24-2005 10:24 PM
Brand new bike bites it... (not my bike) psycho393 General Discussion 9 04-06-2005 04:35 PM
i want a bike with a blown engine or a project bike ridered2 Classified Ads 0 01-10-2005 05:54 PM
