![]() Hi if a motorcycle sits for a period of time like months should it be started from time to time? A little back ground it sits in the garage it dry and safe from elements . Yamaha yz quarantine bummer. thanks |
![]() the biggest concern is the fuel. Either use an additive (stabil) or empty the tank. ---------- Post added at 11:52 AM ---------- Previous post was at 11:52 AM ---------- Oh and I'd make sure the oil is fresh. The acid in the older oil can do what acid does. |
![]() Yes , start it once every other week. This will keep things lubricated as well as keep the seals from sticking to the water pump shaft. Use fuel stabilizer. Paw Paw |
![]() I would change the oil and filter first. Then lube it up, clean the chain and re-lube. |
![]() Been starting the bikes here every other day since pandemic quarantine. Safer to remove the gas if for longer period of sitting. |
Thread Tools | |
Sitting 1 year....What to do? | snapteck | 2-Stroke Dirt Bikes - Yamaha | 3 | 06-13-2012 07:30 AM |
1990 - XR600 - problems after sitting for 2 years | Josh636 | 4-Stroke Dirt Bikes - Honda | 3 | 10-08-2008 02:00 AM |
I'll be sitting on the bench for a little while | yzernie | General Discussion | 13 | 02-11-2006 11:33 AM |
Bike sitting for eight months???? | huffdaddy70 | 4-Stroke Dirt Bikes - Yamaha | 12 | 03-02-2004 07:36 PM |
KDX 200 sitting - Best way to get restarted? | bobwilson2020 | 2-Stroke Dirt Bikes - Kawasaki | 19 | 09-05-2003 10:38 PM |
