Old 09-03-2003, 10:48 AM
HLGuthery 393's Avatar
Last Online: 04-27-2012 07:50 AM
Default Re: Motorcycle Carrier / Trailer
OK OK, I guess I should have posted earlier. I have one.
I opted for the all steel (HEAVY) MOTO SLED brand. It came with a ramp and worked great for me. I purchased some of the cheap ratcheting tie down put one on each side of the handle bars and one under the channel connected to the pegs then used the excess strap to tie the rear tire down. The thing swayed quite a bit but I never had any real problem. I now have a truck but keep it around just in case I need to haul an extra bike or something. IF I were to buy another one it would be aluminum!!! The Sarge Carriers look good!!
Old 09-03-2003, 11:23 AM
hevnsnt's Avatar
Last Online: 04-21-2005 12:51 PM
Perfect! Thanks for the info!!!
After using your suggestion, I found this Review
Old 09-03-2003, 02:30 PM
MotoMan's Avatar
Last Online: 10-31-2018 03:40 PM
Originally posted by Lowco
Dont forget some states are picky about hauling anything like that. If it obscures the tail lights of the vehicle at all, some anal law enforcement types will be ticket happy! Check the laws of your state!
Randy
I never even considered that. Good thought Randy!
Old 09-03-2003, 03:35 PM
Lowco's Avatar
Last Online: 07-28-2007 06:43 PM
Yes its an easy work around with the addition of a set of trailer lights you could hang on the bike or mount on the carrier somewhere. But then you adding to the cost again and a small trailer could be used for more than just your bike, i.e. hauling a load of cement, mulch, building materials ect... Honey Do's!!!!
Plus some of the small trailers Ive seen can stand on their tale and be rolled away taking not much more space than storing that rack system.
Randy
Old 09-03-2003, 04:41 PM
Lowco's Avatar
Here is one I just happened across searching for truck parts!
Small Trailer
Old 09-03-2003, 05:01 PM
Heckler's Avatar
Last Online: 02-20-2015 09:19 PM
I use one all the time. I trust it as much or more than my trailer, and you can haul *** down the freeway and dont have to worry about the 55 mph trailer limit. (I know I dont drive 55 with my trailer either) The best one in your search is the versa-hauler, they are very nice and built good. These hitch haulers are the way to go if you only have to haul 1 bike.
Old 09-03-2003, 09:45 PM
bluebyu's Avatar
Last Online: 08-11-2011 11:32 PM
I'll second the versa haul.My buddy has one and i borrowed it once when my wife wanted to take her jeep.It was well built and the bike did't sway to much.It had a bolt to tighten it up in the hitch.
If you do get a versa haul get the single and not the double.The double puts the weight out to far and your vehicle will really sag in the rear.:
Similar Threads for: Motorcycle Carrier / Trailer
Wanted to Buy-motorcycle carrier DRGSin393 Classified Ads 5 03-20-2009 09:35 PM
Building a motorcycle trailer Jordan #241 General Discussion 7 05-25-2008 03:03 PM
Building a Motorcycle Trailer DCox General Discussion 31 03-02-2004 10:13 AM
NJ: Tilt a Rack hitch Mounted Motorcycle Carrier Wharfrat Classified Ads 6 02-02-2004 12:54 PM
Motorcycle carrier aborg17 2-Stroke Dirt Bikes - Honda 6 12-23-2003 08:16 AM
