Moose Spacer or smaller Sprocket?
This is a discussion on Moose Spacer or smaller Sprocket? within the General Discussion forum, part of the Dirt Bike - ATV - Suspension Forums category; Which one would give me more bottom end? Switching my 50 tooth rear sprocket to a 48 tooth or getting ...
View Poll Results: Which Gives more low end??
Moose Torque Spacer 16 40.00%
Switching from a 50 to a 48 tooth rear sprocket 24 60.00%
Voters: 40. You may not vote on this poll
Old 01-02-2004, 10:00 PM
83SuzukiRM250's Avatar
FordFreak
Last Online: 12-29-2004 11:35 PM
Default Moose Spacer or smaller Sprocket?
Which one would give me more bottom end? Switching my 50 tooth rear sprocket to a 48 tooth or getting a Moose torque spacer?
Thanks, Rob
Old 01-02-2004, 10:16 PM
TheFouledPlug's Avatar
Unstable Pilot
Last Online: 08-13-2006 12:45 AM
Default Re: Moose Spacer or smaller Sprocket?
If you go from 50 to a 48 tooth rear sprocket you would take away low end..... You would have to go to a 51 or 52..... You could also get smaller front sprocket. I have my 125 is geared for more low end and its geared 12-51.
So I had to go with a reed spacer.....BUT a bigger rear would help out also....
Hope this helps!!!!!
Chris
Old 01-03-2004, 09:15 AM
MotoMan's Avatar
Floppy
Last Online: Yesterday 09:02 PM
Yep TFP is correct, going down teeth on the rear sprocket will have the opposite effect that you are looking for.
I would say your best bet would be go for a 51 or 52 tooth rear if you are looking for more torque.
Old 01-03-2004, 11:20 AM
splitfirekx125's Avatar
top dog racing
Last Online: 03-25-2004 11:25 AM
yeah bigger in the and smaller in the front gear u down if u go smaller in the back u would be gearing it up
Old 01-03-2004, 11:35 AM
FordFreak
Ok thanks guys for the info...
Old 01-03-2004, 12:53 PM
YzRacer#53's Avatar
Last Online: 02-15-2006 09:13 PM
Get both
Old 01-03-2004, 05:49 PM
madcow393's Avatar
Custom User Title:
Last Online: 03-23-2009 10:57 PM
id just go for the larger rear sprocket(id go for the 51) but what kinda ridin are you doin? if its woods riding go for the 52 and if you need more torq go for the spacer
Old 01-04-2004, 07:21 PM
Yardpro393's Avatar
393 race team
even though the change is backwards, i voted for a sprocket change. it'll make the most difference
Old 01-06-2004, 06:49 PM
Shocknut's Avatar
Last Online: 05-01-2009 10:30 PM
Yard is right. I've done the reed spacer on several of my toys and I've never seen it come close to matching a 2 tooth change on the rear sprocket. You actually get 2 different effects from them and both would be a good idea. I shouldn't say effects but I mean they give different feel to your powerband.
Old 01-06-2004, 10:04 PM
FFRacing11x's Avatar
The "ONLY" FastForward
Last Online: 03-07-2010 12:20 AM
I don't want to seem too technical here, but Shocknut hit it on the head...changing the gearing will NOT increase torque or lowend. Changing a gear on your 10 speed doesn't make your legs stronger, it just makes it easier to pedal.
Old 01-07-2004, 04:27 PM
MotoMan's Avatar
Floppy
Yep, FFR is 100% correct on that one. It doesn't give you more power by changing the gearing, it can just put the power you have in different spots.....kinda.
Old 01-09-2004, 11:52 PM
Unstable Pilot
Let us know what you did and how it turned out..... Good Luck
Old 01-10-2004, 10:50 AM
FordFreak
ok i will, but it'll be awhile...probably around late March or April...THANKS EVERYONE!!!!!!!!!!
Similar Threads for: Moose Spacer or smaller Sprocket?
moose torque spacer nathan Performance Mods, Maintenance, & Lube 2 09-26-2009 08:46 AM
smaller sprocket? yamaman_488 2-Stroke Motorcycles - General Discussion 14 08-05-2006 08:47 AM
Sprocket spacer valverde General Discussion 5 02-19-2004 03:16 PM
moose torque spacer okayguy 2-Stroke Motorcycles - Honda 10 12-21-2003 07:47 PM
moose torque spacer okayguy 2-Stroke Motorcycles - Honda 1 12-20-2003 07:33 PM
